Huge wow on diy turntable
After 10-ish years in planning and working I (with help of my friend machinist) built my TT. It looks good but does not work good. When it turns, both 33 and 45 PRP, it is running unstable - wow is between 1% and 3%.
Here are what I have so far:
  • TT bearing is made of aluminum
  • Spindle is made of aluminum, with sintered bronze "sleeve" and it is sitting on steel ball at the bottom of the bearing
  • Both base and platter are made of several layers of "butcher block" wood and aluminum parts (yes, they are heavy)
  • Motor is Maxon A-max 110191
  • Mark Kelly speed controller sets speed
  • 3-IN-ONE oil is lubricating
  • I am using a Chemical-Resistant Round Belt, 2 mm Diameter belt from McMaster-Carr.
PLEASE can you point me to what is wrong, how to improve it and make it finally work.
Bearing shaft should be hardened steel. Aluminum is too soft, if that's what you are using. Housing made from Al. would be ok.
It's not very good. I would remove it asap. Even plain old Mobil 1 or Castrol Syntec 10-30w motor oil is better.
jeff
Let me clarify myself B)
Housing is made of AL and shaft is made of AL, with sintered bronze sleeve so it is bronze inside AL.
3-IN-ONE was recommended by few members here, that's why I used it. Also, in the same thread, it was stated NOT to use motor oil because it contains detergent. Other recommendation for oil was a plain Compressor Oil, which I'll try next.
Check to see how much wobble there is at the platter rim when it is spinning. There should be no detectable vertical or lateral change in platter position. If there is, it adds to wow/flutter... And both main bearing & platter balance/machining then need to be examined.
Here's a super simple jig to test the vertical wobble --
Reactions: hbtaudio and Ixnay
It just sounds as though the bearing is not smooth running as it should be. Aluminum is a terrible idea for just about any bearing. At least Stainless steel with a ball at the bottom of the bearing. Yes, maybe the platter needs to be balanced as well.
Reactions: rayma
HI,
A bearing shaft usually is not made with aluminum but rather hardened steel and super polished. Diameter of the bearing shaft usually, for a platter about 5 Kg is 13 to 15mm, 30 mm is by far too big in my opinion.
Balanced platter help.
Motor and speed controller is another story.
Rgds
Adelmo
Reactions: rayma and Ixnay
