Greg:
MY gut feeling is that these are related to TRT Wondercaps, but I can find no supporting evidence for this. I think it would be nice to give a list of caps that will fit and I can help you with those dimensions.
Working on the BOM,can anyone help with a link for the 6.8uF ultra caps pictured in the photos?
Thanks[/QUOTE
Oh no! Another 500+ pages thread!
You could use any other high quality polypropylen cap like WIMA MKP10 or Rifa PHE450.
I like the RIFA somewhat more but differences are small at that low level of voltage. RIFA also has a new type called SMR that uses PPS dielectric that has very little distortion at audio frequencies. Boutique caps rarely show any improvement and are much more expensive.
I realize lots of people aren't located in Toronto or vicinity, but for those who are, this particular capacitor is found in a local surplus store named Active Surplus, on Queen St. near CityTV. It's cost in the surplus store is a few dollars a piece.
ah, that's nice to know 🙂
It looks like something that is axial leaded and is 1.5" long and 1" wide will be the best fit. Not that box caps won't fit, but it could be a tricky fit and would require a ~40mm pitch, which isn't too common but perhaps a 37.5mm pitch might be able to be forced in... This is probably something best tested on the actual boards.
Just lay out the board with space for various pitch leads based on the usual suspect sizes, Wima MKP10, eg.
.. and just like that, all boards are spoken for and I have two boards on the waiting list. Please don't contact me asking if I have any boards. I won't respond. If I do I'll post here.
I don't really even want to ask this, but... is there any advantage to trying to match the BF862 devices?
Hi
As you may have noticed syn08 is not a member here anymore, so don’t expect that he will or can answer your question at this forum.
Anyway the answer to you question about matching is: no
This is what syn08 is saying at another forum: The answer is no, matching devices makes here absolutely no sense.
Cheers
Me too
Hang in there 3GGG. Let me know what I can do once you have the BOM as far as shipping etc.
Cheers
Greg
Cheers
Greg
Has anyone started their build yet? Can anyone tell me the pin spacing for the screw terminal block 5mm or 5.08mm?
Cheers
Cheers
Looks like 5.08mm is the proper lead pitch, but 5.00mm might fit too depending on the diameter of the pins.
- Analogue Source
- Hps 5.1
