P Perry Babin Member Joined 2003 bcae1.com 2021-10-07 3:40 pm #81 2021-10-07 3:40 pm #81 When you said that the output drive was 11v, G-S, was that on ALL of the outputs for this driver board or only half of the outputs? A Achim1409 Member Joined 2018 2021-10-07 3:45 pm #82 2021-10-07 3:45 pm #82 It's only half of the outputs P Perry Babin Member Joined 2003 bcae1.com 2021-10-07 3:57 pm #83 2021-10-07 3:57 pm #83 What's the resistance between the FB pin of the driver board and the drains of the outputs? A Achim1409 Member Joined 2018 2021-10-07 4:04 pm #84 2021-10-07 4:04 pm #84 It's short P Perry Babin Member Joined 2003 bcae1.com 2021-10-07 4:07 pm #85 2021-10-07 4:07 pm #85 Is it the same for the other driver board? A Achim1409 Member Joined 2018 2021-10-07 4:09 pm #86 2021-10-07 4:09 pm #86 Yes it's the same P Perry Babin Member Joined 2003 bcae1.com 2021-10-07 4:41 pm #87 2021-10-07 4:41 pm #87 Do you see signal on the input pin of the driver board? A Achim1409 Member Joined 2018 2021-10-07 4:47 pm #88 2021-10-07 4:47 pm #88 Yes, on both driver cards the same sine wave. P Perry Babin Member Joined 2003 bcae1.com 2021-10-07 4:55 pm #89 2021-10-07 4:55 pm #89 Lift pin 6 of the driver IC. What's the DC voltage on the pad for pin 6? A Achim1409 Member Joined 2018 2021-10-07 5:06 pm #90 2021-10-07 5:06 pm #90 It's on the pad - 9v and on the ic also - 9v..but I damaged the ic now. Broken leg.. P Perry Babin Member Joined 2003 bcae1.com 2021-10-07 5:08 pm #91 2021-10-07 5:08 pm #91 Negative 9v? A Achim1409 Member Joined 2018 2021-10-07 5:11 pm #92 2021-10-07 5:11 pm #92 Yes, ground to bat - and at the grnd pin on the drive board is the same P Perry Babin Member Joined 2003 bcae1.com 2021-10-07 5:16 pm #93 2021-10-07 5:16 pm #93 Have you checked Q3A and Q4A? A Achim1409 Member Joined 2018 2021-10-07 5:17 pm #94 2021-10-07 5:17 pm #94 Not yet.. Tomorrow I will continue. . Thanks for your patience. A Achim1409 Member Joined 2018 2021-10-08 6:50 am #95 2021-10-08 6:50 am #95 It was q4a.. Short... The amp is working. I will order the missing parts. Thanks a lot Perry. Have a nice weekend. Prev 1 2 3 4 5 First Prev 5 of 5 Go to page Go You must log in or register to reply here. Share: Facebook X (Twitter) LinkedIn Reddit Pinterest Tumblr WhatsApp Email Link Home General Interest Car Audio How to check dlogixs dp 4500 drive boards? Top Bottom
