Many thanks Papa... will dig and wait, as said no hurry anyway.
Probably need as amp the equivalent of a nimble lightweight sport car with a big torquey engine - quite an unusual special nowadays
Will though keep an eye on what you will develop next here with these big tins, always fascinating eventhough not for me
Have lots of fun with Xperiments
Claude
Claude
I think, that Nelson's advice is superb (as expected). In your situation F4 would be perfect.
You put yourself in somewhat difficult situation by fixing 2 of 3 pieces of your chain.
If you for example give up on B1 Korg, you could build BA3 pre, or high gain DHT pre (or whatever better suited) and pair it with parallel mono F4's. the lower your impedance, the more power you'll get (it's 100 WPC in 2 ohm) and it will drive difficult loads very well.
But I know, that it's not easy to abandon your latest child. I was in similar situation myself. When after building F6 I build Ale's 01A pre and while both of those are superb on their own, they were not good match together (too much gain).
I'm glad, that I switched F6 for F4, because now I have a perfect match. And for now abandoned F6 will find new home in secondary system.
Also another advantage is, that you will have another projects to work on
Got your point... but I love my Infinitys and my B1 Korg (and if not using it would like an amp that allows straight dac connection), and I do have already a musical amp so basicaly I have no real need to address. One day, I would just like to improve the weakest link which is the amp... while having another project to bolt on as you said.
Of course Nelson's advice is good, but then there are amps that can improve mine while also being superb and fit the existing chain and latest toys... XA-25 being one. I need that gain, although indeed the F4 concept is very attracting.
Thanks for your thoughts and help. TBH the main point here was to find out if I should jump blindly on the Tokin transistors, but in my case they are at the moment probably not appropriate so I got my answer.
Claude
Claude
Say..that power amp of my dreams needs to drive my pair of Infinity Renaissance 90. These are 87dB/W/m, can get down to 2.6 Ohm..
@ ClaudeG
For me best audio upgrade was choice of 8 Ohm wide " full" range drivers with + 95dB/W/m sensibility
for example Supravox - Fabricant d'enceintes & de haut-parleurs haut de gamme have interesting DIY build kit's
with this or similar You can play music without crossovers and power of ~ 20 watt's amplifier is plenty even for large room.
Kind regards
Great quality with price and very good match with Mr. Pass amplifiers
Supravox - Serie Classique, haut-parleurs haut de gamme
Supravox - Serie 2000, haut-parleurs haut de gamme
Supravox - Serie EXC, haut-parleurs haut de gamme
Serie Heritage Archives - Supravox
Naive Frenchy ............
ZM is having and cherishing pair of red ones ....... not my pics
(I know that these are not Supravox ..... , just happens that I have pics with Supravox)
..ZM is having and cherishing pair of red ones ..
Naive why ? Too good yes..
Oh the old red Cabasse can play with Papa Vfet amp but You need find a pair in good shape.
Sometimes contemporary FR drivers is a better choice than vintage
..sometimes not
Enjoy Claude!Thanks you very much for your effort but my Infinitys stay definitely
Me I want change to big Sato style horns with TAD compression drivers
and SIT 10Watt's amplifier. Lot's of DIY wood work
..sometimes not
"naive"
as I said , I have bespoke pair of these Cabasse , originating from Dinghy
and I have some other FR and ER , both old and new
now , being tempted to try Sonido 25cm Field Coils
Enjoy Claude!
TAD compression drivers... YES!
@ WBS
And go bi-amplified with active crossovers.
Single-ended Vfet amp for medium and high's and 2SK180 push-pull " Hulk SIT " for the woofer
PROFESSIONAL — TAD LABORATORIES
.. being tempted to try Sonido 25cm Field Coils
Always look at shine side of life with Papa amp's
You can find interesting DIY enclosures pdf.plans from French Supravox as well from PHY/HP and Fertin Acoustic drivers factory's
PHY/HP products & Enclosures DIY plans
diy
model 8 anglais
@ WBS
Oh yeah!
That's pretty much what I'm doing.
Only I don't have TAD compression drivers, just their woofers.
@ WBS
Active crossovers are meh, great for steep slopes but when a large 3” compression driver can handle 500hz, a first order at 1200Hz with some old GE tin cans sounds very nice. Most of the Klipsch guys would agree. Then you can save your moneys for hoarding SIT devices, or sharing.
Good news 2SK180 and THF-51S matched pairs are back in stock from Tokyo Japan
A pair (2pcs) of 2SK180 (2SK77,2SK182,THF-51S)TOKIN SIT V-FET NOS Original | eBay
A pair(2pcs) THF-51S (2SK77,2SK180,2SK182) TOKIN V-FET NOS Original JAPAN MADE | eBay
Have a nice day
Have a nice day
- Hockey Puck SIT 2SK180 by Tokin source NOS
