Highest displacement per $ woofers 2025
My two cents: If you account for logistics, work, wood, space, amping, things get more difficult. I was thinking going that route too, but calculating all details with 16pcs of 15", it didn't look that straightforward and ideal. When accounted for all this, these 18" and 21" units don't look half bad.
Tested (measured) yesterday.
Full review, as with the Alpine SWG-1244 (see OP), will be on my YT channel, eventually (I have enough other content for now). In the meantime, I'll spare anyone interested in these drivers the expense and will share that the 17mm Xmax claim is, as somewhat expected, bogus. The distortion limited output of the GAS turned out significantly lower than the SWG-1244's with its true 10mm excursion ((30mm Hvc - 10mm Hg) / 2).
Nice to know. The Alpine is more than twice the price where I live, but still the Alpine is very reasonable priced.
My modelling program seems to like it.
vs Dayton RSS315HFA-8 in box just over 2 cubes. No EQ:
A little Linkwitz Transform later:
Just as deep and extended. 8dB more output. Same volume box.
My login price: €220
Reactions: Crashpc
One of these 24"s is likely the king.
233€ for a high excursion 24" sub just need to buy in quantities.
Quad stack of FE magnet, it's a heavy SOB.
Somewhwere in the 40/50mm area for xmax. Would need to send a email an inquire.
https://jldaudio.en.alibaba.com/pro...tml?spm=a2700.shop_index.88.26.58001a80XYLyaG
price in singles on another website.
Those are being resold in Europe under different brand names for 2-5 times the price.
Reactions: stv
Interesting that no 24" driver under $1K will provide Xmax numbers in single quantities.
