High sensitivity driver amplification
That's an expression commonly used to mean "not zero and not infinite", IOW not completely ignorable. Drivers coupled to acoustic horns have significant mechanical damping, so in this respect are less sensitive to electrical source impedance. They still have frequency response variations with different source impedances, of course, so the matter can't be completely ignored.
Although many do, and live perfectly happy lives.
All good fortune,
Chris
attachment.php
looking at the 1 meter fr, one subtractive filter should get the response ironed out to begin with. Sensitivity will lower, I can either turn the amp up or the input signal or use additive eq instead...
If aiming for 115db max system spl what power should I aim for with the AXi2050...I plan on covering 400hz on up with it.
