WConstants.h simply includes wiring.h
#include "wiring.h"
Why not just include wiring.h to begin with?
#include "wiring.h"
The hifiduino code for our dac was the same as heartwinter sent to us... Doesn't work...
As a test I downloaded the buffalo II code and uploaded it. Works at once (if I had a buffalo dac that is.). It would have been nice of heartwinter wich version of the Arduino IDE he used to get the code to work.
Brgds
Did you try the Arduino compiler 0022 revision? I believe the code was created for this version.
http://arduino.googlecode.com/files/arduino-0022.zip
Do
Thanks Do! I'll give it a shot when time is given. I still believe that it should be rewritten for Arduino 1.0. A confirmed functionality would make things simpler to convert.
Brgds
Brgds
#include "wiring.h"
Wouldnt this be Wire.h in Arduino 1.0?
BTW: I can't find the declaration of what pins to use for the LCD in the hifiduino code...
Brgds
Brgds
This isn't what Heatwinter sent us ? I know several people have used the hifiduino code with the WM8741, if the hardware is the same it has to work. Is the issue that Heatwinter recommended a different display?
Also need to be using the old sony remote.
Or is it that since the Hifiduino code was written the Arduino hardware has changed?
Guys, stop bashing your heads and use the 0022 compiler link I gave you above... Most of his older projects were using this version of the compiler.
Now I'm not 100% sure but I've uploaded some of his older project code with it and it worked A1...
Ciao!
Do
Ciao!
Do
Hey guys, the code for wm8741 has a few "requirements"
Uses Arduino 0022 (Arduino 1.0 changed the code)
Uses Sony Remote
Uses a version of a serial interface for LCD (you can find the requirements in the old blog)
For the BII code, I got smarter 🙂 and coded for the simple parallel LCD and upgraded the code to work with Arduino 1.0
Uses Sony Remote
Yes, thank you Do and glt. I have the parallel display which won't do with the code as is. The simple solution would be to get the serial display but it would be more fun to rewrite the code for the parallel one.
Brgds
Brgds
This might be a solution...
Microcontroller Projects: 16x2 Serial LCD (Two Wire) with PIC12F675
Brgds
Brgds
One peculiar that I do not understand is this one:
LCDi2cW lcd = LCDi2cW(4,20,0x4C,0); // Initialized the library
compare it to:
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); // where I use 10, 9, 8 and 7 instead of 5, 4, 3 and 2.
The first one is from the provided lib and the second one is from the new LiquidCrystal lib... What is (4,20,0x4C,0) ?
Brgds
I think you should be able to use the liquidcrystal library.
The (12,11,5,4,3,2) are the Arduino pin numbers that the LCD are connected to. So, if you use 10, 9,8,6,5,4,3,2, than you had better connect the LCD to those pins, or it won't work very well 😉.
Here is a code snipet, to show how to connect and define, using pins
2,4,7,8,12 and 13 as shown.
BTW, for the Arduino, these pins have different functions, for example D0 and D1 are the serial interface, so you can't use there pins.
#define RS 2
#define ENABLE 4
#define DB4 7
#define DB5 8
#define DB6 12
#define DB7 13
LiquidCrystal lcd( RS, ENABLE, DB4, DB5, DB6, DB7 );
So, in this example, you would connect the LCD RS signal to D2 of the Arduino, LCD Enable to D4, etc. Note the the LCD D0-D3 pins are not used, only 4 data pins are connected, D4-D7
4 and 20 would be the size of the LCD, its a 4 x 20 LCD. 2x16 is the most common size. Not sure what the last two parameters mean.
Randy
Oh, one more thing
I decided to try building an active, digital crossover, most likely using a PC for the crossover, and then using a multichannel DAC of some type.
So, this project has been shelved for the time being, since it doesn't apply to that project.
May or may not build this in the future.
Randy
Randy
I've downloaded and installed the early version (0022 compiler) of Arduino, and I followed the instructions:
"This code requires LCD12cW.h for i2c LCD from Web4robot LCD and macros.h
for defining the large characters. Download library from:
Arduino playground - LCDAPI and select "LCD12cW".
After downloading copy the folder "LCDi2cW" to the "libraries" folder in
the Arduino folder. "macros.h" is inside one of the examples in the examples
folder. Move it out of that folder into the LCDi2cW folder
When I compile I still get the following error report:
core.a(main.cpp.o): In function `main':
C:\Arduino_0022\hardware\arduino\cores\arduino/main.cpp:7: undefined reference to `setup'
C:\Arduino_0022\hardware\arduino\cores\arduino/main.cpp:10: undefined reference to `loop'
TheGimp - change the name of your toplevel codefolder to something else than the name of the codefile itself. It will at the next time you try to open it tell you that you must have your codefile in a directory and it wants to create it and move the file. Let it do so and the errors will be gone.
Brgds
Brgds
I thought I did that when I loaded Arduino-0022.
I'll strip it out and start over.
edit...
Same results.
I moved the code to the root directory which is Arduino-0022.
I executed Arduino.exe.
I opened "Arduino UNO Code.pde" from the Arduino-0022 directory and got the message that it needed to be executed out of it's own named directory. I let it create and move the file. I closed Arduino, restarted it and opened the file from the new directory. When compiled I get the same message.
edit...
Same results.
Thanks Randy.
Yes, your example is for the parallel LCD. Might the second one be for the serial LCD?
I will have to read in a bit more on this since it's my first attempt on Arduino.
Brgds
Brgds
edit...
Same results.
Strange, I got that error with 1.0 and with help from google got the directions to do what you just did and it worked. Sorry that I can't test it right now, I just downloaded 0022 and are looking for glt's code in some other format than html ;-)
I will probably get the same error as you did.
Brgds
Thanks Turbon,
I tried rebooting just in case there was something dangling in the setup and got the same results.
I'll look into it later as well. My granddaughter has company coming over and I'm the cook so I'll be busy a while.
It looks like it is squaking about this code:
#include <WProgram.h>
int main(void)
init();
setup();
for (;😉
loop();
return 0;
In the file - "main.ccp"
in this directory.
However I don't see where it is called from.
Is there the equivalent of a "List File" option with Arduino so I can see what the compiler is doing?
int main(void)
init();
setup();
for (;😉
loop();
return 0;
in this directory.
I was looking at the code, but I couldn't find LCDi2cW.h anywhere?
The arduino link is broken.
So, I spent a little while messing with it, using LiquidCrystal.h instead, and after making changes for that library, I can compile without any errors.
If you want to use a parallel interface LCD, this is what you would need to do anyway.
I could post somewhere if there is interest?
Oh, and for this code
Yes, it is for a serial LCD. Pretty sure 4 is rows, 20 is columns, and 0x4C is probably the I2C address of the LCD controller.
Gimp
Can you take one of the simple example Arduino programs, and compile it OK?
Not sure where the "main.cpp" program you are talking about is, since arduino source files should be .pde
You might try cutting and pasting a simple program into the screen you get when you start arduino, and make sure you can compile ok.
Randy
Gimp
Randy
- Digital Source
- High Performance WM8741 Upsampling DAC New Version build thread (show 'n tell too)
