High Output Subs that play 20Hz to ≥200Hz
Shes a ringer... But After crossing, she rings no more... Sorta impressed? Is this too good to be true? Why aren't these things all the craze?
yes but the Topic of this thread is
High Output Subs that play 20hz to ≥200hz​
Thats not happening with a TH, can you explain the distortion part? The 1w sensitivity in these sims are 5db over a similar sized Sealed cabinet, at 20hz and 30hz
Bandpass? A 4th order bandpass? You are talking about a TH as a 6th order bandpass?
I guess I asked the question lol! OK I see your point... but for the thread title I mean, This offset BR business seems to fit.
good ole offset driver 'qw' resonator with three 60 cm folds? your driver has a super compliant suspension and a low QES, kinda interseting. Might need to enlarge all of this to fatten up the bottom end ?
(there’s a bit of stuffing in the 4800cm2 x 60 cm offset stub section)
Reactions: camplo
You left off the ‘mass loaded’ port/shaped section? That might have shortened the resonator down to 120 cm (~216 hz as the (3x 1/4 wavelength) pipe resonance @ top off requested bandwidth )
3 fold again? port @ like 1/3 Sd though? didnt you used to design them like this back in the qw group court?
Reactions: camplo
