High damped vs. Low damped
Now I'm seriously confused. I used to believe that my Q = 0.6 was overdamped. Now I am hearing that it's underdamped. 🙁
By the engineering definition, yes, systems with Q values greater than 0.5 are technically underdamped.
But from a practical stand point, loudspeaker systems with Q values of 0.5 to 0.707 are considered 'well' damped.
Structures and thick panels may be considered well damped with Q values from 1 to 10, so desired Q values are application dependent.
Don't let the words of the technical definitions for Q overly guide the determination of practical desired values for the particular application.
"The Q-factor or quality factor is defined as the ratio of energy stored to the energy dissipated per cycle for under-damped systems."
