HIFONICS ZXi 1008 car amp stuck in protect mode
Put the rectifiers back in the amp ..
Remove U1 that sits behind the driverboard ..
Insert a 10 amp fuse in series with the B+ wire ..
Try powering the amp up dies this allow the amp to power up?
Only try powering it up for a few secs since it may draw current so remember to insert a 10 amp fuse in the B+ line
all steps completed. Powered up...Protect light on.
ok so now what do I check?
Thanks and Happy Holidays
Tom S.
post the voltages on all 16 pins of the power supply IC on the driver board b careful not to let the probe slip between pins.. Black probe on amps ground terminal.. It's either a 494 or 7500 IC can't remember which one the amp uses
Post as followed
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
post the voltages on all 16 pins of the power supply IC on the driver board b careful not to let the probe slip between pins.. Black probe on amps ground terminal.. It's either a 494 or 7500 IC can't remember which one the amp uses:
power supply control IC is a IL494D. See attached datasheet.
Pin 1: 2.7v
Pin 2: 4.53v
Pin 3: 4.6v
Pin 4: 18.2v
Pin 5: 1.55v
Pin 6: 3.4v
Pin 7: .1mv
Pin 8: 12.09v
Pin 9: 0v
Pin 10: 0v
Pin 11: 12v
Pin 12: 11.21v
Pin 13: 5.02v
Pin 14: 5.02v
Pin 15: 5.02v
Pin 16 7.8vv
  • IL494D.pdf
