What would be a good reading for the zener diodes. I think the last time I tried to test them they gave open line in one direction but in the other it showed like a capacitor was charging up because the readings keep changing. I will check again and then report back what I find.
If both read the same, they're likely OK. If you remove them to check them, they will likely read about 0.7v one way and open with the probes reversed (meter on diode-check). With the meter on ohms, they would read open one way and 3-4M ohms with the probes reversed (but that depends on the meter).
Without "easter-egging" this thing any more, what is the best way to test this amp to figure out what is wrong with it and if it can be fixed relatively inexpensive? As of right now there are no output transistors or driver transistor for the output in the board and all of the rectifiers for the power supply have been removed. There is 12 vdc going to the mosfets of the power supply but the protect light is still on. Did I miss checking something?
Did I read it wrong previously? I thought that you stated that there was no protect after removing the rectifiers.
The supplies are not independent if the center legs of the rectifiers for one supply connect directly to the center leg of the corresponding rectifier on the other supply.
disregard post #72. The correct state with rectifiers out there is no protect light on tested for about five minutes and still no protect light. Quickly explain to me if you will about the power supplies. Is one generating rail voltage for the output and the other generates the 15 volts for the opamps?
The area around the driverboard in front of it and in back of it ..
Hopefully this is what you need. I can take a shot of the bottom side as well just PM me.
Tom
Put the rectifiers back in the amp ..
Remove U1 that sits behind the driverboard ..
Insert a 10 amp fuse in series with the B+ wire ..
Try powering the amp up dies this allow the amp to power up?
Only try powering it up for a few secs since it may draw current so remember to insert a 10 amp fuse in the B+ line
- General Interest
- Car Audio
- HIFONICS ZXi 1008 car amp stuck in protect mode
