I took all of the output fets out and the driver card and I still have dc on the low side drain. Does that suggest the problem is on the ps side?
I guess it depends on your definition of 'power supply'. I don't think the problem is in the supply drive.
What else still has voltage in the amp when you have the 20v?
If I use the main ground I find it on both sides of the 2.2k resistors but 0v across the resistor
I spoke with Sam from Barevids about it this issue. He had me check if there was any dc on the speaker terminals. It was present on both pos and neg speaker terminals. He suggested I run a jumper between the neg battery terminal and ground. That seems to have solved the issue. Obviously there is some component or trace that has gone open somewhere but i havent been able to locate it so this seemed like a good solution since its my personal amp. If anyone happens to find the fault since it appears to be a common issue, please let me know but for now connecting the audio and main ground seem to be working g fine.I am currently stress testing it in my vehicle. Been about a week now of at least an hour each day. So far so good. I will update if anything changes.
It may have engine noise with a direct connection. R-GND and C-GND on the diagram are the components that you need to find in your amp.
any chance you still have this amp? curious if you could tell me what your C gnd and R gnd readings are or what it says on the chips themselves. i am having the same problem and would greatly appreciate it.Ok. I found R-GND and C-GND. Neither is open
I do still have the amp. I believe they should read 0 ohms. If yours read different let me know and I will check.any chance you still have this amp? curious if you could tell me what your C gnd and R gnd readings are or what it says on the chips themselves. i am having the same problem and would greatly appreciate it.
- General Interest
- Car Audio
- Hifonics BXX4000.1D
