I spoke with Sam from Barevids about it this issue. He had me check if there was any dc on the speaker terminals. It was present on both pos and neg speaker terminals. He suggested I run a jumper between the neg battery terminal and ground. That seems to have solved the issue. Obviously there is some component or trace that has gone open somewhere but i havent been able to locate it so this seemed like a good solution since its my personal amp. If anyone happens to find the fault since it appears to be a common issue, please let me know but for now connecting the audio and main ground seem to be working g fine.I am currently stress testing it in my vehicle. Been about a week now of at least an hour each day. So far so good. I will update if anything changes.
any chance you still have this amp? curious if you could tell me what your C gnd and R gnd readings are or what it says on the chips themselves. i am having the same problem and would greatly appreciate it.Ok. I found R-GND and C-GND. Neither is open
I do still have the amp. I believe they should read 0 ohms. If yours read different let me know and I will check.any chance you still have this amp? curious if you could tell me what your C gnd and R gnd readings are or what it says on the chips themselves. i am having the same problem and would greatly appreciate it.
- General Interest
- Car Audio
- Hifonics BXX4000.1D
