Hifonics BXI1500D Help
ok they are removed.
what should i check for?
the regulated voltage +-15v is present on the opamps.
Q9C1, Q9C pads BLACK PROBE MAIN POWER GROUND
1.) 4.522
2.) 62.20V
3.) 4.92
Q11C, Q11
1.) .001
2.) .003
3.) .389
Q10C1, Q10C
1.) 6.345
2.) 61.99
3.) .650
Q12C, Q12C1
1.) 6.129
2.) .649
3.) .001
the 4080 heated up again.
pin 6
Did you ever replace the outputs in this amp at any time ?
I’m wondering since the outputs in your pics are IRF3710.
If you replaced the outputs the 3710 causes problems in the 4080 based amps and they should be IRF3710Z (Z prefix improtant ). Only pointing this out .
If they were replaced at some point and you didn’t replace them with the Z version I would replace the HIP4080 again and the outputs to the Z version
