Hifonics BXI-6000D
With 2ms no Signal possible, changed to 2us.
removed the bridge and resistor. Still the same. Relay not switching, DC between the inductors.
If i measure on the collectors without input i have a clean square with same amplitude on both.
If i measure on the fets, the working side has amplitude, the not working only dc. Maybe q2 defective?
checked all resistors, ok. changed q2 (2D) against KST92, still the same. Mut be one more problem on the drive board. The Signal is not reaching first resistor in front of the board.
checked signal on pin 12, got dc. other 21844 on pin 12 good signal.
