For u.fl, I use these: U.FL-2LP-088K1T-A-(60). E.g. from mouser.Very simple question what exactly are the specs for the jumper cables for connecting those I 2S signals ?
Notice to Buffalo 3 users:
The Buffalo 3 requires 8 channel input, so you need to provide either 4x I2S, or 8x DSD lines.
The BBB is capable to generate data on 4 lines, thus for DSD channel remapping has to be used. Otherwise some internal DACs of ES9018 will generate just silence.
So in general BBB needs to play 8 channel PCM audio to have same volume as stereo SPDIF data input.
With ES9018 channel remaping you can decrease number of needed channels to 4.
The data channels resistor area on Cronus can help with that too. Omiting some resistors and using wires on the side close to the DAC, there is possible to interconnect some channels of BBB together and not tie outputs of IC4 at the same time.
Yes great point! This is precisely why we don't mount resistors - because if you parallel channels on the B3 for (to make it run in stereo remapped mode - B3SE style) you will only want to mount the output resistors that go to BCK, D1, and D2
what about jumper cables,are they 2.54mm socket/pins?uFL is just not all that DIY friendly (the low number of mating cycles and the fragility of contacts) - and not as good as directly stacking. But uFL is just fine provided you are able to use it as intended.
Yes there is a 2.54mm (2 x 20 + 2 x 4) header. And terminals for B3SE style (GND, BCK,D1,D2) wiring. Wiring that will work work very well too as long as the wires are nice and short.
Opus DAC does not have U.Fl connectors or option to solder them I believe ?
What is a B3SE style terminal?
Yes it is important if you are shorting signals the B3 to omit the resistors that are not actually driving the net. So for typical stereo B3 usage - only install the resistors R5 - R7 on the Cronus. Then use the jumpers on the B3 to enable stereo remapped usage.
I assume the same is true for BII?
So is anybody making music through the hermes Cronus yet?I am anxious to hear.
Hi Russ,
First of all, I'd like to thank you and your team for this great work.
The boards were delivered last night. Today I assembled the boards with 45/49 Rhea. Soldering went quite smooth but I made a small mistake to solder the Cronus header to the wrong place, intending to preserve the space for handling uFl.
After several attempts with no sound, I became aware that I was wrong with choosing holes. Leaving the already soldered header as it is, I added other header pins to the original (default) holes and succeeded in getting sound.
Playing DSD128 and PCM on B3SE via teleporter and these board is quite smooth but I'm going to check the details in the weekend. Included is the picture of my rough setup. My next step will be to find a new box for my B3SE and Hermes-Cronus with BBB.
BTW, I'm still using software clock divider by miero instead of H/W divider on the board. If I'm going to use the latter, I think that there is no necessity to edit kernel option for clock rate setting. Correct?
Best Regards,
Hi Russ,
Best Regards,
Congrets on first sound
Here are the dimensions for the Hermes-BBB. I hope it helps with planning.
Hi Russ,
Got my Hermes Board (no parts) yesterday, very fast to Germany! Thanks for it.
I believe to have all the right parts, but a schematic or part list would be nice for soldering.
Thanks in Advance.
- More Vendors...
- Twisted Pear
- Hermes-BBB/Botic cape for BeagleBone Black
