I built several prototypes of PP amps with GU-50 outputs. I like them a lot. You can't get such quality of sound from 6L6-like tubes, like KT-??, 807, etc... However, it is not the best tube for SE, but compared to 807 in SE it is much better.
Is the last 3rd picture a PSE ?? love that
Yes, the last is PSE. Unfinished project.
A right-handed one
You could also try building it MJK-style, but without DC-connection. There is a thread somewhere about it http://www.diyaudio.com/forums/tubes-valves/165221-most-linear-triode-strapped-pentode-7.html#post2204502 . Will probably measure better than the 6E5P but don´t know about sound.
Albertli,
This is a simplified model where your PSU and OPT will work(400V/3,5kohm). Will clip at ca 30V ptp into 8ohm. 6E5P at 200V/12-15mA.
Lars,
Thanks very much. I certainly do make a try on this. I have to digest more before I know how to ask some questions. Hope you would tell me more.
Thanks again
Albert
Not sure if of any use here, but was playing today with my curve tracer and did a plot for the GU-50 in triode mode. Unfortunately my anode supply can only swing to 300V at the moment, so curves are limited to that maximum anode voltage.
I took measures from the plot indicating that gm=4.4mA/V, u=4.5 and ra=960. Does it sound about right? 🙄
You can download the curves from here:
My Photos
Ale
My Photos
Ale
My PSE prototype
This is my PSE prototype - almost finished. B+ 410V, driver ECC801S in SRPP, negative bias (GU50 - around 45mA each), OT 3.5K:8Ohm. Interstage caps: Jantzen Audio Superior 0,22uF. Frequency response from 8Hz - 35Khz 0dB. GU50 in pentode mode - sec grid around 255V. Power >20W/8Ohm.
My Photos
Hi Ale;
it would be nice if you show the curves up to +10 Volt on G1. 2 more lines on the picture! 🙂
Hi Anatoly,
My tracer can do up to +5 or 10V I think. Let me try and see what I can do. Will post hopefully tomorrow.
Cheers, Ale
Cheers, Ale
Albertli,
Lars,
I'll make out a psu for your comment.
Do I aim at 100mA tube bias with -28v ??
Albert
Revintage's circuit will work very well.... my circuit is very similar, but my 6E5P run with a simple resistive plate load only. You could run the load as in Revintage's circuit, or with a resistive load or replace the load with a 60-80 Henry choke for the 6E5P.... each will have it's own special sound quality.... try it and pick the one u like the most.
A choke is a very good idea. Would go for that if it was doable. Unfortunately it will be hard to tame the resonance peak in the low end. Resistive load is doable and sounds good but you can expect a significant rise in distortion compared to gyrator.
Hi Ale;
Hi Anatoly,
Got only +5v, but strangely enough the +5V is squeezed to the 0V curve. Any idea?
http://www.bartola.co.uk/valves/Construction_gallery/Pages/Traced_curves.html#0
Ale
I thought it was the case, but checked with the oscilloscope and had a perfect step at 5V with no signs of the driver struggling to provide current.
Attached is the driver circuit. with the 10K resistor I think it can't provide more than 1ma there...
Any suggestions?
Ale
Any suggestions?
Ale
Thanks and would love to try all those you recommend. I thought I'd start doing it as of Lars design. I'm making the wood chassis and would cut the aluminum top plate sometime next week.
Albert
- Tubes / Valves
- Help with these Russian GU50 tube amplifier
