Thanks! That is great news.
I think my biggest hurtle will be to figure out how far down I should place the driver as I’ve read even mm’s can have an effect on if some internal resonances will be cancelled.
Also I have found on my search that this SB 8” driver has quite similar (VAS,QTS,FS) efficiency and Xmax as the cube audio FC8. They have some interesting designs on their web site for DIY ers.
Oh that’s great! Thanks for the direction, this is my first mltl project and am hoping for a positive outcome rather than just a pile of saw dust and a light wallet.
I know MJK worksheets are not available, but HornResp is.
And I believe there was a sim made in the other SB 20 thread.
Yes, I did see that other thread with the hronsrep sims for different volumes and enclosures. That’s how I decided on 66L enclosure. I did also look the the “accidental mltl thread”, which helped me immensely to clarify how a seemingly reflex design achieves quarterwave development.
I just only have Apple products IPads and such.
Hornresp will work on MacOS using Whisky which is a skin UI for the game prior toolkit and Wine. Works fine. Available on GitHub.
I’ve downloaded a program called “ speaker box lite” for iPad. It kinda works.
I don’t think there are any emulators available for iOS devices to run windows.
Thinking about that, given that Parallels on the the new Mx processors often runs Windoz better than many Intel boxes, i wouldn’t be surprised to see a version running on Mx iPad. And also maybe WINE (& Crossover Mac) for well behaved Windoz software.
Looks a lot like this online one of the same name, https://speakerboxlite.com/
First pass thru — very cumbersome and hard to get where i wanted.
dave
dave
Yea I’m limited to IPads at this time for my computer power. I did use that “speaker box lite” program for a sub I put together a few years ago. You observations parallel mine with that. I did’t feel it was suitable for optimizing an MLTL design. Or at least I don’t know how to use it correctly to get what I want.
Perhaps I should just stick to a BR alignment for this and use other online calculators.
Although setting the driver at 21% line length is inline with what I have read and observed with other diy designs for a MLTL.
Another concern may be that setting the driver that low in a midsize (36”) cabinet certainly won’t be optimal for a seated listener.
Thank you all very much for your help so far!
Based on the plans for the A8, and the Altec 515 specs, I get the cabinet is around 200 dm3, with s slit 16" x 1", long 3/4 inch (cabinet walls), that tune it to something like 38/40 Hz, up to the woofer natural Fs. It's right or wrong?To the 1st approximation all vented alignments adhere to the basic BR align
A belated response:I have read most other threads that have mentioned this driver and many concerning MLTL design along with MJK’s site. I just don’t have access to the worksheets or Hornsrep and would rather not use “rules of thumb” to determine driver and port placement.
I’m estimating the driver being placed somewhere between 20-23% down from the top of the line and port approximately 4-5 “ up from the bottom.
Note that driver(s), vent(s) ideally need to be at a pipe's odd harmonics, so with 'L' = internal height, 'Z' = driver and using the acoustic center of clustered drivers........
Z = (L)x ~ 0 (top), 0.217, 0.349, 0.424, 0.561
Vent offset only, depending on box HxWxD ratio: Z = (L)x ~0.651, 0.714, 0.848, 0 (bottom)
I mean the slit port tune the cabinet at a higher frequecy than the woofer (Altec 515-8LFE) natural Fs.... that tune it to something like 38/40 Hz, up to the woofer natural Fs. It's right or wrong?
No clue without knowing what specs used as they changed quite a bit over the decades, nor how you're calculating a slot vent > 9:1 where it's already somewhat aperiodic. I had to experiment by 'critically' damping the vent, but in general it will be fairly large due to its high Vas and somewhat > Fs due to its powerful motor.Based on the plans for the A8, and the Altec 515 specs, I get the cabinet is around 200 dm3, with s slit 16" x 1", long 3/4 inch (cabinet walls), that tune it to something like 38/40 Hz, up to the woofer natural Fs. It's right or wrong?
Sorry to resurrect an old post. However, doing some research and came across this from OP post number 80. This doesn’t seem right but nobody commented on it. Am I missing something? ThanksThe vertical brace going from bottom to top is not connected to the front or back.
Yeah, just wondering if I misunderstood him. Seems it should be attached to the front and the back of the cabinet or it’s pretty much well worthless.if it worked for him.
- Full Range
- Help with cabinet design for SB20FRPC30-8
