Help me put these tubes into good use... I need a project
Ok. I had returned. About 14Km in bicycle wheel #26 from home to dad and mum's and return.
OK to all. I see you could make it works. Crystals are capricious. Tubes too. So sometimes it is difficult to advance a result. Now make several tryes to shut down and on the oscillator to make sure it is capable of self start without touching the plastic gang.
How many turns got the coil?
Nice work.
I had tryed many times. Basicly it starts no matter the gang position, it doesn't make any difference if I turn it. Only if I have DMM connected (ground and plate), then it needs to be fully counter clockwise and it has few degrees of headroom before it stops working and voltage drops to -0.70.
It is strange. Turning the gang from one extreme to the other, it must increase the signal until it suddenly stops and no more signal. Same in the reverse.
I am taking a bit of fresh air under the shadow of my dear tree. It's warm today.
Reactions: diy1995
Well. Now let's try to transfer oscillation to the pentode's grid. Hook a 100pF from triode's plate to pentode's grid and a 100K half watt resistor from grid to ground. Cathode grounded and plate & screen leaved unconnected. Then measure pentode grid voltage.
I get -1.25v on the grid and I have silent tone on the receiver about 3000hz by ear.
Buzz disapears when I turn off the oscillator, while tube is cooling down only 3000hz tone remains audible.
Well. Try to reduce the 220pf at the right of the Xtal (as I drawed in the circuit) some value arround 47/56/68 pF.
I have no clear the reason for the ~3000Hz note, it may be an heterodyne with other signal.
Also try disconnecting one side of the gang or both and confirm that it isn't shorcircuited internally. Sometimes the thin plastic film that acts a dielectric may be broken.
Also check tube heater voltage. I don't understand why the oscillator can't give almost 5V of bias in the triode's grid. If the tube is used, perhaps it is exausted or faulty.
Reactions: diy1995
https://en.m.wikipedia.org/wiki/Armstrong_phase_modulator#:~:text=In 1933, Edwin H.,produce a frequency modulated signal.
I don't know if it has been used in commercial transmitter. There was another specially designed tube to get FM directly called Phasitron:
http://lampes-et-tubes.info/sp/sp006.php
Indeed, Armstrong is the inventor of this method. In the early 70s, curious why this method had been abandoned, I started constructing a semiconductor version (fundamental frequency 200 KHz) and found out the real problem: it's the amount of frequency multipliers. Unless each stage is thoroughly isolated from the others, there's enough feed-through to mess up the spectrum. The proper way would be to use a few PLLs and binary dividers, back then expensive.
Reactions: Osvaldo de Banfield
Off-topic: Is it possible that I can get chinesse, russian, and some other language (that I don't know, but it sounds like from far south) stations with my old cheap receiver? Receiver is from mid 70s, made in yugoslavia... with fact that yugoslavia was kinda known for low grade electronic devices.
Many international broadcasters are using hired transmitters as close as possible to the target area. So here in Panama I can here a program in English from the Czech republic on 15,770 KHz - a transmitter located in Florida, USA: http://www.wrmi.net
One of the few "from home" broadcasters is RRI (Radio Romania International). Very powerful transmitters (100 KW), good directional antennas and also quite a few transmissions in DRM (recently updated from 2.5 to 5 KHz audio).
The 3000hz tone was indeed from some other signal. It's not here today.
Heater voltage is 11.4vac, that would be about 8v rms... that is a bit low...
I can try with DC from adjustable psu.
Will test the gang and find what cap I have to replace 220pf.
Tested the gang on 200mOhm range... it's just L (for out of range) showing on the DMM.... tryed to replace gang with the other one... same results...
That would explain it.
Changed heater psu to dc 9v...
triode's grid voltage is -0.54v (but it seems to be higher if DMM is not connected, because I can see the voltage falling quickly when I connect the DMM, it shows -0.65v at first fraction of a second.
Plate is 78v with gang far CCW and 55v with gang far CW.
It does a nice consistent fall while turning the gang and buzz starts to go attenuated when voltage gets pass 67v and lower. But just when I have DMM probe on the triode's plate or pentode's grid, otherwise gang position still makes no difference.
Pentode's grid voltage is -0.91v with gang far CCW and -0.61v with gang far CW....
Pentode's screen voltage is -5v...
Edit: changed the 220pf cap for 100pf (as I dont have 47, 56 or 68pf) and triodes grid went to -2v... will check my scrap pcbs for the lower cap... this looks promising.
Yezzzz. Short waves had been used during decades for international transmissions. I remember had ear that there were stations with 500KW! Think your oscillator is about 1/2W, so it equals 1 million oscillators like your one. Sincerelly I don't know if actually the SW stations are on air. I remember Radio Netherland, the VOA (Voice of America from USA), RFI (Radio France Internationale), RTE from Spain our RAE (Radiodifusión Argentina al Exterior), TELAM (our official news agency), etc. Several stations those era had spanish language transmissions and they gift some kinds of things: Radio Netherland send once a year the entire program for spanish transmissions to South America. Thus I listen several sundays a program called "La estación de la alegría" (the funny station). We wrote them and I remember a white, red and blue cubic box that function as a calendar, money box and had the station logo in one face; and a QSL card they sent at mail return (no email nor internet yet).
This includes the now extinct RTTY, only actually use by some few hams around the world.
I am not sure if it was during the Gulf War, I received in a short wave tube General Electric radio some RTTY signals. They were SSB (Single Side Band, the normal AM transmission but the carrier and one sideband [AM has two sidebands at each side of the carrier] removed by a special cristal filter). So you need a beat oscillator to listen them properly. RTTY sound is fun. Thus, with my brother Rolo now in USA, we built a simple converter with a TL081 powered from the serial port of a 386 PC. The opamp ran open loop and only convert sine waves into square waves and those was input into the serial port DB25. An old program HAMCOMM runing under DOS 5.0 let we see in the screen the teletype texts. One must descifre it because signals were weak, l lack a proper aerial and the beat oscillator (6BZ6) was far from perfect at those times knowedge. So the original text was mixed with abnormal characters like:
"Sinc4 thosw timz to nowwm6ch @Ears $ad p%st"
The obvious text was:
Since those time to now much years had past.
But characters appear quikcly at the screen (75 characters per minute) and there was no time to reread, so one must be fast to understand the text.
In fact we read by those means news that never was said in the radio ot TV during those times.
Those era of analog communications...
Reactions: Aridace and diy1995
Now thats some history.
I found 47pF cap and I think that it is good now 🙂
-4.2 on triode's grid
102v on triode's plate
-1.65v on on pentode's grid
-5.30v on pentode's screen
And perhaps much more expensive to build than simplest reactance modulators.
