hello, how about this booster for amplifier
another view
hi longthrow is that your cab?
nicely done huh...
BTW I've seen the output transformers are those the size of the 200watt ones. Or are those the ones that are customized.
and the input ones, are those the vt65's or still customized?
:hot:
macweb
How about learning some higher tech?
Considering that yours is a mobile application, where lowest power consumption, low weight and small size are desirable features, I would do some research on things such as class G, H and D and push-pull SMPS if I was you. For example, I'm currently designing a custom 2 x 150W@4ohm class D amplifier for motorbike audio. It's going to be small for easy installation and it's going to waste very little power into heat to allow playing loud music without overloading the electrical system.
Audio frequency transformers are bulky and heavy, they distort subs and trebble, and they use lots of copper which is a semi-precious metal whose price increases every day (that's probably due to te huge amounts of copper wasted in stone-age applications like low frequency transformers and old-school electrical systems in vehicles and buildings :bawling: )
hi eva,
i agree with you & were completely aware of that (post#55,71 & 73),in fact i personally go for class h..:angel:
but this low-tech scheme is the topic here..🙂
thanks for your comments!!!😀 😀 😀
"in fact i personally go for class h.."
Since you said you were using 36V from batteries, you have a 12V, 24V, and 36V tier available. Refering to the diagram in #46, all you need do is add a couple of diodes at 45C and 46C, tie them together and use that for the level shift zener to drive the switch circuit for the high voltage tier.
You can have the high efficiency without the inverter, and with a DVC woofer you don't need the output transformer either.
It is used now a days, because was the simplest way, the cheapest way...
to increase power... a very low cost sittuation.
The cheap automobile amplifiers are using this kind of schematic even now a days when we have Class D units with 4000 watts of output.
Distorts a lot...... but if you listen music into the automobile...well.... quality is not really what they want (HERE!)... they want some punch only..... and they use to spin around the town avenues producing their Thump, Thump, Thump!
hehehehe.... sometimes used to guitars.... well..guitars already have distorters.... this makes the music seems to have more "body" as some folks say.... distortion from guitar plus distortions from amplifier produces a beautifull mess.... and that's all they want.
They are on the mood..want to show themselves, if they can paint body with yellow and tie a rope around the neck holding a big wattermellow to be "VERY VISIBLE"...then they do!
Those guys are spending little money and producing strong and loud sound... and that is what they want (HERE, down here, in Brazil, South America)
Sometimes, speakers are associated and resulted into 0.25 ohms....ahahahahah!
I felt them a little bit ridiculous...but they feel i am ridiculous and they are special, great, famous, popular and beautifull "Show man"
regards,
Carlos
