Headphone amp NE5532
I want to make headphone amp with NE 5532. We have many in stock.
I have attached one circuit.
Guide me in the matter.
Any other suggestions are also welcome.
Here is a very interesting circuit for a headphone amp.
The bias for the output is controlled so that all of the output transistors remain on all of the time, thereby eliminating crossover distortion. The workings are explained in this article:
http://www.edn.com/contents/images/6702272.pdf
Hat tip to Bigun for this one.
The circuit in post #1 is basically a method for paralleling a buffer with an amplifier, but it has little to do with the bias.
Also note that not all amplifiers will tolerate the additional phase shift.
Regarding this one http://www.edn.com/contents/images/6702272.pdf, it is instructive to look at J Broskie comments about it (bottom of the page):
http://www.tubecad.com/2010/04/blog0186.htm
What is the impedance of your headphones?
As hinted by the circuits above, you need some extra grunt to properly power lower impedance headphones to full volume (<250 ohm). Common op-amps do not do a good job by themselves.
Many popular headphone amps are based on this:
http://waltjung.org/PDFs/WTnT_Op_Amp_Audio_2.pdf
It is a diamond buffer done with discrete components. Many common transistors can be used 2N4401/3, 2N3904/6 etc.
See part 1 for where the buffer fits into the op-amp circuit:
http://waltjung.org/PDFs/WTnT_Op_Amp_Audio_1.pdf
Try this.
If you have plenty of 5532's, then you can easily build a nice little HP amp with 60-80mA of drive which should be fine to drive a 32 Ohm set of 'phones.
Also, if you look at my website, I built and measured a very simple class
A HP amp that acheived great results.
I have a circuit for a headphone amp that I've been using since 1986.
It was design by late Barry Porter and has a current dumping output stage and works well with any phones from 32 - 600 ohms. I'll post the circuit later.
Thanks for input from friends here. DualTriode, abraxalito & Bonsai.
I am waiting for the circuit from msdin.
The circuit of Mr. Bonsai is having 5 opamp in parallel as buffer.
do we need so many to drive 32 ohms load?
As per dual triode just one buffer stage ok.
Herewith attached one more circuit seen at the following post.
http://www.diyaudio.com/forums/head...mittor-follower-headphone-amp.html#post658897
Just one darlington transistor is used.
Kindly comment on this circuit.
which will be better? with 5532 as buffer ( 1st one) or Darlington BJT ( with this post) as output.
A TO-220 device in a headphone amp? That should really do the job. You could even drive a small speaker with that circuit. Fairly loud as well. 😀
That current source will need a bit of slide rule work to implement. Drives me nuts, that. I've seen too many of them in scholarly articles and text books - kind of a shorthand for a bunch of components. You know the drill - it is left as an exercise for the reader. :scratch: :xeye:
Just one darlington....but with a 200mA 'black box' current source and a fair sized heat sink to go with both!
Class A for headphones is neat though...
The 5532 is designed to drive a 600ohm load up to 10V, that is around 17mA .
Lets say your design goal is 100mW of power.
This is sufficient to get most headphones really loud with some headroom.
For a 32ohm resistive load that implies a current drive of 55mA.
A single 5532 cannot do that even when shorted to ground.
For a reactive load like headphones you will require even more current to reach 100mW, lets say 92mA with a power factor of 0.6 (just a guess).
Then there is the impedance of the 'phones which is not really 32ohms - it may drop below 32ohms at some frequencies.
Bottom line is you need mulitple 5532s as buffer,
or a real buffer chip like the venerable 634 (if you can find them),
or do it discrete.
One more circuit, with a good write-up, from ESP:
Headphone Amplifier
For a list of headphone power ratings:
HeadWize - Technical Paper: Understanding Headphone Power Requirements by Dennis Bohn
<snip>
or do it discrete.
<snip>
[/URL]
Hello,
I am not sure how “buffer” is used in this thread.
In post 1 and as in the TI Application Note linked in post 8 of this thread the 5532’s are operating in parallel, there is no buffer insight. The two 5532’s in parallel will source 70ma.
Remember the 47R resistors shown in series with the Op-Amps in the circuit when doing the maths.
DT
All just for fun!
