You are too kind Stuart. The speakers are butt ugly. But in the end will be beautiful I'm sure.sounding and looking good Bas
Although I have a good headphone system, It's not easy to tell how good a speakers Is through a recording, but compared to other stuff I've heard they sound very nice. Dynamic, full of energy and life (I hate bland or dull speakers) - good job Bas.
Ideally, You just need to get some measurements done to see If any tweaking to the crossover can Improve the sound. Or have you already done some measurements?
That would be ideal. But I have zero crossover tweaking experience...and/or measurement. That is the main reason I'm building the 18sound design exactly as designed.Ideally, You just need to get some measurements done to see If any tweaking to the crossover can Improve the sound. Or have you already done some measurements?
Thanks...but I cannot take credit for an 18sound project- good job Bas
The devil is in the details.How do you find the high frequencies?
On my main system with DDDAC or DurioSound DAC and SE EL84: lovely.
On my kid's system...chromecast audio and standard lm3886 gainclone: bleeding ears.
Oh I see. A good DAC Into a valve amp
Highs crossover part finished
Wax coils and z-superior caps - I bet they weren't cheap
True. Got ex-demo discount on the 4,7uF's and on the wax coils. Still. Total price for the crossover parts. 209 euro.Wax coils and z-superior caps - I bet they weren't cheap
I should revise this. Not so much bleeding ears as there was just too much of it. Probably because the gainclone is more "honest" when it comes to the higher frequencies that are there.On my kid's system...chromecast audio and standard lm3886 gainclone: bleeding ears.
I added a 1ohm resistor in front of the highs....and now it sounds much much better on the gainclone. Still to be tested on the valve amp.
Progress...and a question. Would it be possible for the port to exend to the outside? We got ports cut in wood because that would look better. But the angles prevent it from going full length. So now we thought...wat if we go 2cm outside?
Nevermind. Got the answer....and a question. Would it be possible for the port to exend to the outside?
- Have 18Sound ND1030 + XT120 and want to get Faitalpro 8PR200
