Hardbass mono not turning on
All four outputs removed. This is what I see on the gate legs of Q207 and Q208 in the first pic, and Q209 + Q210 in the second pic.
Not sure if this is usable data from the DSO, or if using the OWON is a requirement to achieve usable data.
This is what is on the last two pins of the driver board. There really isn't anything else on any of the other pins when checked with a scope or multimeter... This is with the scope grounded to the - speaker terminal.
Some progress. I replaced the two 10ohm resistors and jumpered the speaker- terminal to the GND terminal and there are signs of life. The power up sequence with the LEDs occurs with the red protection lighting up for two seconds and then the green led illuminates. The new driver board voltages are posted below.
No audio as it goes into protection as it powers up with outputs installed. +rail voltage goes to the speaker terminal. Getting +rail voltage on the gates of the high side outputs.
With nothing connected to the Amp, there is 36k ohms between GND and Speaker - terminals.
Pin 4 with the +17.7mv sits at 12.7v without remote and all the way until the red protection LED turns green and then it drops to 17mv.
Pin 6 rests at 3mv without remote, when remote is applied, there is a slight jump in - voltage and then it drops back down to 23mv or so.
Discovered that the 74HC02 ICs are damaged when I went to check them. I have MM74HC02MX on hand, can I use them as replacements?
