Hacking the Logitech Z5500
I don't have PIN6 :rolleyes:
I test all the wires with my tester and tester doesn't sound PIIIIII.. :p
My wires of "control" are 7,8 and 12. I think my pin12 is like PIN6 of other systems.
In this xmas holidays I will open my subwoffer and look for any broken component. I think my problem begin into the amplifier... :(
Thanks Adrian Vista. I will post my progress here too ;)
I could not wait :p
I opened the subwoffer and have not found anything bad :confused:. Here I leave some photos taken of the subwoffer PCB now.
The problem I have now is that when I touch with my finger the signal wires for each of the 5 speakers would have to hear a buzz. Well, that makes it buzz only when I touch the blue wire, which is the center speaker, it is as if the other speakers were not connected ...
The photos:
you can find something bad?
Gallery:
ImageShack -
Direct Links:
http://img300.imageshack.us/img300/4986/19122009339.jpg
http://img42.imageshack.us/img42/4264/19122009340.jpg
http://img300.imageshack.us/img300/659/19122009341.jpg
http://img38.imageshack.us/img38/9837/19122009342.jpg
Thank you.
This is an automatic translation from Spanish to English. Reviewed by me and I think this well written :)
I have to dessold this wire?? but if I dessold this wire and then connect to the same wire to GND there is no conection no?
Wire dessolated ------------------ GND
There is no sound :(. I have connected all the wires to the pod but signal wires no. Now, I can turn ON the speakers correctly, but if I touch the signal wires the speakers doesn't buzz! :S. I don't know what's wrong...
Thanks.
If I connect the blue wire (i think is PIN8) All the speakers sound, incude the subwoffer. And they are buzzing, buuuuuuuuuuuuu....
And with this wire, if I touch any signal wire, the speaker of this wire sounds PFPFFFFfffPFP :p. And the same for the subwoffer.
To eliminate this buuuuuuuu.... I have to connect the subwoffer signal to gnd or any signal and this buuuuuu.. disapear. I have to buy a 10kpot for subwoffer signal.
Thanks!
