GZTA 1.1200
Hello! Could someone help me with this amp. GroundZero 1.1200dx-ii monoblock. Protection light is right on and nothing happends. Measured all fets etc, no problem found. TL494 pins 9 and 10 measure 0volts so there is no pwm at outputs eather. Changed the TL494 but no help. What could cause this, any ideas?
Pin 16 is driving it into protect. Lifting that pin and grounding it may get the amp to power up enough to see what problem is driving it into protect.
You'll have to be careful since the protection is going to be disabled.
Have you tried to get a diagram from GZ? Sometimes, those outside of the US have a better chance of getting the diagram than we in the US do.
Okay thank you Perry. I did what you told me and the amp powers up. Nothing drama happened, no dc at outputs, rail voltages ok and so on. But..with 1V/50Hz sine I didn't get anything at output. Seems like the signal is migging from output fets.
Think that U509 (in the picture) could be IR2010?? If so, then at pins 1 and 8 (HO and LO) is coming nothing out.
Okay took time to get measured but now I got the results 👍
Pin 1: 0,00
Pin 2: 0,00
Pin 3: 12,40
Pin 4: 0,06
Pin 5: 0,06
Pin 6: 48,3
Pin 7: 47,9
Pin 8: 48,0
Pin 9: 0,01
Pin 10: 0,01
Pin 11: 5,01
Pin 12: 2,30
Pin 13: 4,49
Pin 14: 2,71
Pin 15: 0,00
Pin 16: 0,00
Yes. Now when the shutdown pin is lifted. There is almost negative rail voltage (-46VDC) at output. And one part marked Q12 on the power supply side is heating really quickly and gave a little smoke.
E: Q12 = D882M
Has the voltage on pins 12 and 14 changed significantly?
Post the DC voltage on all terminals of U107.
Only power up for a few seconds at a time to prevent doing more damage.
I didn't state this earlier but n some instances, the 494 will not function properly when a distant ground point is used. Grounding to pin 7 is less likely to cause problems. If you have some old stranded computer ribbon cable that you can use for a jumper, it's less likely to break the pin on the IC.
I don't see Q12.
