Balanced input for DSP
3e-audio: It would be great if you could offer a balanced input board for your DSP - since the amplifiers are already balanced and the DSP has a balanced output. This would create a complete balanced chain. Any thoughts on this ?
39 total,officially confirm via email.I count 46. 2 of the posters were buying more than 3 items, so would they be 2 separate orders?
some of them may forget to send email for order placing.
let's see.
since the design use the on chip ADC of ADAU1701,so it only support single-end analog input.3e-audio: It would be great if you could offer a balanced input board for your DSP - since the amplifiers are already balanced and the DSP has a balanced output. This would create a complete balanced chain. Any thoughts on this ?
Im planning to add to the group buy/order.... its deciding weather to get 2pcs of each amp.... :/ £££
it depend what power level you want to achieve.Is one EAPST-0400-48-A enough to drive 2 EAUMT-0260-2-A?
normally we calculate:
smps power = 1/8 of maximum power(1/3 in pro-audio)
260W/8/0.85(efficiency)=38W per channel.
4 channel total will be around 152W.
sure,if use 2 smps to drive the amp separated,you will get more headroom and less thermal on the smps.
it depend on design case by case,and also budget in another word.
it is included.Is usbi included when ordering dsp,or do i need to add usbi to order?
- Group Buys
- Group buy: TPA3251_TPA3255 Amplifier board and ADAU1701 DSP Pre-Amp board
