Good morning,
I have a pair of three-way speakers and I would like to create a 6/8 channel amplification system to drive the drivers separately
@3eaudio What configuration do you suggest to buy?
6 ch or 8ch?Good morning,
what is the speaker impedance and power rating?
6 ch or 8ch?
I would like to create an active crossover system for these boxes
Frequency Range 38 - 20000 Hz
Nominal impedance 8 Ohm
sensitivity 87dB / 1W / 1 meter
Crossover points 450 and 4500 Hz
Exchange filter Linear phase
Continuous power 200 Watt IEC
Peak power 300 watts
350 Watt musical power
Dimensions (HxWxD) 860x270x330 mm
weight 19.5 kg
The cabinet contains 4 speakers. Lagetones up to 450 Hz, 2x 180 mm speakers. Midton from 450 to 4500 Hz, 1x 120 mm midrange. High tones from 4500 to 21000 Hz, 1x 60 mm. Tweeter band
i assume 200W rms is all of them totally(3 speaker units per box)I would like to create an active crossover system for these boxes
weight 19.5 kg
you can use 3255 for all of them,
or 3255 for woofer then 3251 for Mid and High.but you need 2 type power supply: 48V and 36V
ok many thanks.
i think that if i use 3 tpa3255 i need 3 power suply.
probbably i'll chose 2 tpa3251 2 and 4 chanel
3251 2ch+3251 4ch will be a good choice for home application,50~80W per channelok many thanks.
Audio Mo - Dubai UAE
EAUMT-0260-2-A-1
EDSP-1701-24-A opt2 QCC3008(5.0)
Would QCC3008 support A2DP? I use iPhone
EAUMT-0260-2-A-1
yes,A2DP,AVRCP,AptxAudio Mo - Dubai UAE
EAUMT-0260-2-A-1
A3an _ The Netherlands
EAUMT-0260-2-A – 1 piece
EAPST-0400-48-A – 1 piece
EDSP-1701-24-A-opt2 – 1 piece
- Group Buys
- Group buy: TPA3251_TPA3255 Amplifier board and ADAU1701 DSP Pre-Amp board
