Hallo Per Anders
Just a hint regarding your SSR03 BOM.
Here in Germany it was very easy to get these WAGO modular PCB Terminal Block with pushbutton but nearly impossible to the 4 and 12 port versions. Perhaps you change the Block items to the modular ones?
You can built to any pole number. They are like LEGO.Hallo Per Anders
I think it will consume 30 mA but it's possible to tune down the consumption a bit with increasing R17 and R37.Im using the 24V LM431 bom. Its intended to be on for weeks, but in standby about half of the time ... Also wondering about the trafo,is 2x24V 100VA for maximum load of 1A pr rail OK?
Very nice board, the quality is top notch.
This is true. And they are easy to get.You can built to any pole number. They are like LEGO.
This is the reason why I mentioned to take these (0256-0401) into your BOM instead of the 0256-0405 and 0256-0405
- Group Buys
- Group buy: SSR03 Super Regulator Power Supply Board
