I've gone ahead and ordered the parts as above, sufficient for 8 sets after my 2 which is enough for all those that expressed an interest. The cost per set of components was £28.83, Postage for 2 sets will be in the region of £4.55 (there's nearly 1Kg of caps!) for first class so hopefully you'll all be happy if I set the price for 2 sets at £65 including postage. Any surplus will be donated to a deserving audio forum.
Hi Paulski, any chance of one more set of components?
Question which may have been asked before ?
I need 8 outlets
From a twin outlet mains wall socket is it ok to have 2 separate DCT-03 in 2 separate cases each with 4 outlets
Just double checking ?
Alan
I need 8 outlets
Alan
The filter can handle 12 amps so you can have as many outlets you like if you have control over the fuses.
Per the fuse could be a problem as 13A could be overloaded with 8 items
If I can have 2 boxes then I can half the load
Do you have a part number for the Wago connectors for 2.5mm sq flex
Alan
Farnell https://se.farnell.com/wago/0256-0402/terminal-block-pcb-2-position/dp/1258648
I have those also for sale.
Hi PA - have you a price for these ? Getting shafted at Farnell with £15.95 delivery from US
Cheers
Rob
The two last boards are posted today (to Wealas) so by that I'll hope all of you have got your boards.
It's closed. I forgot to change my page about it. I might check the interest after the summer for another group buy.
I see that there is an interest in an additional group buy. Sign up on my wiki page if you are interested. See my signature.
- Group Buys
- Group buy: DCT03 DC trap (filter) for toroidal transformers
