I've gone ahead and ordered the parts as above, sufficient for 8 sets after my 2 which is enough for all those that expressed an interest. The cost per set of components was £28.83, Postage for 2 sets will be in the region of £4.55 (there's nearly 1Kg of caps!) for first class so hopefully you'll all be happy if I set the price for 2 sets at £65 including postage. Any surplus will be donated to a deserving audio forum.
Hi Paulski, any chance of one more set of components?
The filter can handle 12 amps so you can have as many outlets you like if you have control over the fuses.
Per the fuse could be a problem as 13A could be overloaded with 8 items
If I can have 2 boxes then I can half the load
Do you have a part number for the Wago connectors for 2.5mm sq flex
Alan
Farnell https://se.farnell.com/wago/0256-0402/terminal-block-pcb-2-position/dp/1258648
I have those also for sale.
Hi PA - have you a price for these ? Getting shafted at Farnell with £15.95 delivery from US
Cheers
Rob
- Group Buys
- Group buy: DCT03 DC trap (filter) for toroidal transformers
