Best 1.5 inch CD waveguide for using between 20khz and 500hz? Driver is JBL 2452SL. I've found SEOS 24 and JBL 2384.
Does anyone have measurements for these or suggestions for a better alternative for a in wall corner speaker?
Thanks.
Thanks.
Really looking to get down a little lowerthan 750hz if I can.
The SEOS 24 (diysoundgroup) unit has a 7degree throat angle , but my driver is 0 degrees. I assume I can't 3D print an adapter as the geometry is not like old type horns that have a constant geometry. - they seam to change from a straight line at about 45 degrees for most of the horn into a tight radius just before the throat entrance.
This would mean I am left with a 7 degree sudden angle change....not what I'm looking to pay that kind of money for.
Are there any alternatives? Or would I have to 'roll my own?'
The 2452 is a throat-less design. I highly doubt it would make any difference worth mentioning. The wave at the exit is never perfect anyways. Might be spherical at some frequencies and planar at others before any influence of the horn takes shape.
The phase plug extends all the way to the exit instead of having a short(or long) conical section leading to the exit.
Isn't the phase plug inside the outer portion of the WG, terminating at its CD interface aka the throat?
Why not print SEOS24 for your driver?
The SEOS 24 is huge! Can't be printing that beast!
It was my understanding that a 7degree angle mismatch would cause reflections in the throat.
How could there not be a throat?
Hello Noah
Here is a cross section with a JBL throatless driver using a coherent wave phase plug
Rob🙂
Thanks for the helpful picture, Rob.
I submit that the throat is effectively the ID of largest diameter air passage, which I assume you'd want the ID of the WG throat to match in dia. and angle, which looks to be 0 deg.
I can print if needed - I've designed SEOS ten years ago for AVS forum.
For crossing at 750hz, i loved the 2384.
I have 2374, 1" sibling.
Larger than SEOS24 and controls directivity easily under 1k.
just cheap plastic and i have covered these with 4mm bitumen mat
Appears to be hereBMS 4550. price = us speaker used to stock this for about $150, appears to be unobtanium now. SAD!
Assitance Audio - BMS
though I haven't tried to buy any.
If the QSC waveguide is gone bye-bye, what could you put this beast on? The response goes really low. One of the BMS?
Assistance Audio is the US Distributor for BMS; US Speaker sources their BMS drivers from them.
Yes, you could probably buy direct from Assistance Audio, that's how I got my 4540NDs.
not sure how low you want to go, but 18Sound makes a nice horn that measures very well and sounds nice too
Eighteen Sound - Professional loudspeakers
XT1086 is one of my favorites but the QSC measures a little bit better.
XT1086 is handy if you need narrower vertical beamwidth.
The nail in the coffin is that:
1) The XT1086 is aluminum, which makes it hard to work with for a Unity horn, if that's your goal
2) You can buy five of the QSCs for the cost of the 18Sound
3) Unfortunately both are discontinued
- Great Waveguide List
