Good Toroidal Transformer recommendations?
Putting together a power supply and I need a 50VA 9 volt AC output.
Is there a particulary good brand to get?
I am in the UK so something available in Europe would be best.
Any recommendations?
Thanks,
skibum
I order my transformers from Toroidy.pl - they are cheap, but absolutely worth recommending. My Gainclone went a whole league up after just changing the old trafo (which was previously a very decent Nuvotem Talema) to one of theirs. Make sure to ask for a transformer in "audio realisation" version - these come with a Faraday shield, shielding between windings and grain-ordered steel core as a standard. Also dead quiet.
I recommend also asking them to wind primary over secondary, and to use a 50% thicker wire for secondary (don't ask me why - Peter Daniel tipped me off about this and trafos do seem to sound better this way).
Only thing is, the postage can be quite expensive...
Well,
Goss, not gost 🙁 Goss for "grain oriented silicon steel"
As far as I know, silicon steel is the usual material for transformers magnetic circuits.
I doubt "goss" is best for magnetic shielding, the best is mu-metal or permalloy.
Yes sorry typo its Goss and as you say its purpose is to reduce the stray magnetic field. It may not be as good as MU-metal but its better than nothing
Alan
