Gemme Audio VFlex magic
I am not sure why measured distortion when presented as 2nd, 3rd, 4th , 5th harmonic plus THD vs frequency is meaningless? It totally provides an instant indication of how clean the speaker will sound
Stuck there are we X? Where are the studies that correlate these too what we hear? The only one i've seen says it is meaningless. And 45 years of experience.
Dismissing it as worthless would mean that there are speakers that you think sound good but have poor HD plots?
Distrotion is important.Measures aswe dothem know is avery poor indicator of what that is.
you need clean HD in order to not bury the 20 to 40 dB of signal in the presence of the main sound.
You need low information loss to get there. But your measures do not tell you much about that.
I am still unclear if this signal is in the bass, mid, or treble range?
It's everywhere.
or downwards means that you have a SNR that is high so that detail at the -40 dB relative to the music can still be discerned?
Sort of. It is bigger than that. It has been shown the humans can hear signalwell into the noise.
The term dynamic range is perfectly understandable and well defined as ratio of largest signal over smallest resolvable signal. Cannot be better than SNR.
Not really what we are talking about.
What is the equation for DDR? It sounds like it should have an equation because the term seems to indicate a quantifiable variable.
Equation? At this point it is a concept, a way of thinking. At some point i truly hopd it will be quantifible. But we have a lot tolearn about measuring audio. And probably even more important what the ear/brain needs to create an enjoyable illusion.
dave
Not hard to find research on the topic of HD audibility.
http://www.almainternational.org/assets/PapersLibrary/2013WinterSymposium/measurement%20of%20harmonic%20distortion%20audibility-listen%20inc-alma%20ws%202013.pdf
Also see this very good paper and references therein:
http://www.bksv.com/doc/bo0385.pdf
Perceived distortion is affected by frequency it occurs at (400 Hz and above is more important) and duration of the signal. But certainly it is audible and makes a difference.
It is audible otherwise manufacturers would not use so many things to make the drivers lower distortion - like shorting rings.
Some interesting reading. Having more of a history on visual side of things [photography and HT], I can see a lot of parallels in specific terms being used here.
I was intrigued with Dave's DDR... to me this is a measure of 'Contrast'... Play a twin tone [or two instruments]. Keep the Primary at a constant level and drop the level of the secondary. Measure or listen, until the secondary is lost amongst the harmonics of the primary [or can't be heard by ear], the difference is the your personal/measured range of contrast ... Perceivable/measurable contrast, DDR.
But that'd be the highest level of contrast in a black against white way, music isn't that simple 🙂
Just a thought...
Paul
1st line slide 2 "Conventional distortion measurements such as THD do not show reliable correlation to the ear’s perception"
Exactly what i have been saying. They are exploring other ways to measure that correclate with what/how we hear.
A typically well written piece by B&K (a company selling measure equipment) on how traditional distortion measures work.
dave
Planet10,
I agree THD is not the best but I am referring to looking at other harmonics and the paper does use other orders of harmonic distortion for their neural network based algorithm to derive the Perceptual Total Harmonic Algorithm (PTHD). They are not saying harmonic distortion is not useful. This is exactly the point of the research - that there are other ways to define distortion.
Planet10,
But you talk as if it is.
Distortion is distortion. What we measure is a small subset. This paper tries to take what we do measure already and run it thru an algoritm that attempts to present it in a way that gives them some correlation to perception because as it comes out of the box it is not.
dave
My point is if THD was Jack or zero, by definition, all n'th harmonics are zero as well - you have a pure tone output for a given sine input. If nonzero then having the n'th order harmonics, preferably up to 5 are useful. But zero distortion is better than finite distortion.
I'm aware of what your point is, and it remains irrelevant to what I said, which was not about levels, but the fact that a summed THD number tells you nothing useful. It's about the practical utility of the measurement, not distortion or the lack thereof. Individual levels per order can tell you something of value.
I'm scratching my head here.....The fact that you have a summed thd usually means that you have visibility of the individual levels......or am I missing something??
is there a piece of software/kit that just shows the total??
is this with respect to having measured the amplifiers thd immediately beforehand to isolate it's contribution...I too, may have missed the point.🙂
