GC Preamp Suggestions
Here is the one I will make for me. OPA627+BUF634 (dip8 package).
Thanks a lot, MaxW. Nice board🙂 If this is gonna end up with a GP as G. set out to do, we have to make a decision at this point😉
What layout do you guys want?? If this is gonna result in some kind of GP, more of you guys have to attend😉 Please express your thoughts😉
Steen.😎
Finish etching my stereo board.
It doesn't look like much, but hey its the first thing I have ever etched. 🙂 I will populate it and test it tonight. I will be offering a group buy for this circuit as I have already recieved about 20 emails asking for it. 😀 And I have not even tested it yet! 😱 😉
I was a little off aligning the silkscreen. I did not use transpancy, just photo paper.
This is for a little mixer/headphone amp. it is based on the circuit from this thread, but a few minor changes, it will be switchable between 50 ohm cable driver and headphone amp
I need a few more parts for the PSU board before i can test it. the PSU output is a little high to use without regulators (+ - 19v ac from 14vac wall wart transformer )
I think the amount of time i saved by not making a circuit board was wasted figuring out how to put everything on the rat shack mini board. dont do it 🙂
OK, I have finished building an testing this preamp. 🙂 Here are some pics. It works great! :up:
For my testing since I knew my source was very quiet(no RF noise) and had no DC I simply jumpered C3/C4 and C1/C2. I have a simple audio taper 10K stereo pot on inputs.
I used 10ohm 1% for the output resistor(R9,R10) for all tests.
I used 550ohm 1% for the input resistor(R1,R2) for all tests.
I used 220K (well matched) 5% for input to ground (R3,R4).
All feedback resistors are metal film 1%
For kicks I tried two different types of electrolytics for the bypass caps.
1) 47uf 35V low leakage types. Which were OK(better than nothing), but I found that the midbass really lost its edge.
2) 47uf 35V very low ESR Nichicon which were much much better in every regard!!! I am sticking with these. 🙂
The .1uf bypass caps are some polyester metalized film caps I picked up while back. They sound great. I also used Wima MKPs and did not notice any difference at all. So I am sticking with the originals. They are about half the cost too!.
For unity gain tests I used R5/6 of 4.7 K and R7/8 of 4.7K.
For G=3 tests I used R5/6 of 2 K and R7/8 of 4K.
For G=6(approximate) tests I used R5/6 of 1 K and R7/8 of 4.7K.
I succesfully tested:
OPA627 - gains of 1, 3 ,and 6
OPA637 - gains 3(worked fine evene though spec G=5 min), and 6
OPA227 - gains of 1, 3, and 6
OPA228 - gains of 3 (also worked fine), and 6
LT1115 - gains of 1, 3 ,and 6
LT1028 - gains of 1, 3 ,and 6
AD8610 - gains of 1, 3 ,and 6
This is one VERY transparent pre. I am extremely happy with it.
This simple circuit makes a great headphone amp if you keep the Zout low especially at the lower gain (When connected to my SACD player unity gain was best). Sound got really thin when I increased Zout. Sound was best with straight wire.
Here are two pics, the first is the PCB design, the second the finished pre with +/- 15VDC PS.
Cheers!
Russ
Nice Russ!
You're like a robot spitting out your builds 🙂
Can i ask when you were testing it with headphones wich impedance your headphones have?
I have build peranders QRV-04 (opa627/buf634) and i also can say that without output resistor it sounds best (with 300ohms H-P). Now when i think about it i have a SMD inputcap on that amp and as i know i don't have any DC from my player i'm must try to bypass it 🙂
Latest buffered pre design
I had some time to tinker. If you want to run a buffer biased you really should use the TO220 package, so I did here. I also left plenty of space for a heatsink as you will verly likely need it.
I used the LT1010 simply because I like it a lot. I find it equal in my testing to the BUF634, yet it is less expensive and easier to obtain.
This design should work for just about any single opamp.
It would make a great headphone amp, and will pump out 150+ ma. easily.
Any feedback?
BTW the jumper is there for insurance. I probably will not need it, but I wanted pads there just in case.
Don't laugh I am still a n00b!
Cheers!
Russ
Here is the schma too:
