GB Thread for Salas SSLV1.1 BiB shunt reg
I've never had a single issue with shipments from the US... all of them slipped through customs unopened.
I'd be interested in 2 boards... I don't really need a small kit since I can source most everything locally (and I have IRF's and diodes already). Only those 1R resistors are not easy to find 🙂
Hi, was playing with the scope just now trying to track noise once more. To no avail with my scope. Its best is 5mV/diV. So I set it there and to 10us. From GD to AC it just seems brighter, not thicker when the reg is on, and the rascal gets a wee bit thicker only if I power the reg off. And that is with smallest 4u7 on output. I asked my bro for visual opinion, he took the mickey, so I quit.😀
😱 Not cheap at all! It cost more than PP.
There are Siemens, Vishay, Wima MKS4, and BC Component orange ones in Europe. All will work nicely. I was able to get everything needed from local shop for the BiB, apart from the K117GR naturally. The RIFA are good and biggest value in 22.5mm for anyone wanting them so they had to be referred to also. Mouser is rather expensive many times I have seen. Has to be the premium for stocking that massive gamut maybe.
Salas
this Is better than DCB1 used as a regulator ?
what are main key features between two pcbs
This is a general regulator, easily configurable, has different open loop gain and damping characteristics. Faster. The DCB1 on board regulator is mainly ''voiced'' and configured for DCB1. Has no remote sensing or features for easy different voltage targets and uses TO-247s.
