Salas,
I don't seem to be able to download the write-up.
You should wait for 1min until the server gives green light. Else, provide Tea with your email to send it to you. Its ~1.8Meg, it does not load up here.
Salas
as I understand you do not recommend IRF 240 / 9240 as a hot road but IRF 520 / 9520 ?
where can 2sk117GR be sourced
No I don't recommend 'em if you want it to play as intended. 9610/9530 as in BOM. For K117GR Ebay has plenty. For typical shops I did not query.
Salas,
Thanks. Will do.
Thanks. Will do.
Remote sensing is a good idea Salas, all well done :- )
Positive and negative side to side in mirror can be a symmetric +/-V reg. Third board can be a spare positive reg, or each one on its own. Break with a simple move (V-Grooved), still strong when together. A typical need is +/-V for output analogue stage and +5V for digital stage in a DAC for instance. You can use the two +V sections from the triplet for double mono B1 is another possible use. Download and read the guide, says everything.
If it helps-I can order a good deal of the 2SK117 GR's. I should be able to sell them for .50-75 cents each. I am also considering getting some of the needed transistors, and 1/4 W 1R resistors on hand, as these seem to be PITA parts to locate for some. I would not mind a show of hands so to speak what and who would like this.
I put for two boards in the spreadsheet, I would be interested in any of the hard to get parts you can supply.
I have put a copy of the build guide here.
https://docs.google.com/document/d/...LIiGvNU6YYamCqlmk/edit?hl=en&authkey=CM7d-IkL
The formatting may not be perfect. but it's up there.
I have found a seller that has the 2sk117 and diodes, pots some fets etc for good prices with low shipping charges, I have used them before and recommend them. Tayda Electronics Home Page. Pitty the irf9540 is not recommended, they don't have the IRF9530, but have most all other semis.
Will play with 9540s too, but the Zo bandwidth will close in and curve up a bit. On the other hand the minimum Zo will be 20% less. If you have and want to put, you can certainly see for your self.
eagle files
is it possible to post the eagle files for this projekt. I will use the shunt regulator for dac project order to replace the existing power suply.
best regards
Dirk
best regards
Dirk
Per Rail 'Mini-Kit'
I have priced out (potentially) some mini kits that I think will ship fairly easily in my manila envelopes. The pricing is per rail. Let me know what you think. I think the shipping cost will go up a buck or two per rail as well - as most of you are international buyers.
The kit includes the below. It doesn't include-
No caps, connectors, pots or resistors for set adjustment. No R201 resistor (A Xicon 10R 3W MF or MOX could be added for .50)
Postive Rail -
2-1R resistors 1/4W MF KOA Speer
2-270R Xicon 50ppm 1/4W MF
1-47RXicon 50ppm 1/4W MF
1-IRF9610
1-IRF9530
1-BC550C
4-MUR260 (2A 600v) DO-41 Diodes
2-1.9v LED red 2mmX5mm (like what I use)
3-2.1v LED yel 2mmx5mm
3-2SK117GR
Estimated Price is $8.50
Negative Rail
1-BC560c
1-IRF610
1-IRF530
3-2SK117GR
1-47R Xicon 50ppm 1/4W MF
This Rail is less expensive - N channel parts. 7.50
Positive LV
3-2SK117GR
2-1R resistors 1/4 MF KOA Speer
1-IRF9610
1-MJE15029
$7.50 per rail
Negative LV Rail.
3-2SK117GR
2-270R Xicon 50ppm 1/4 MF
1-47RXicon 50ppm 1/4 MF
1-IRF610
1-MJE15030
Est. Price is 7.50.
I could leave out MUR's (about a buck), LEDs, about a buck. But I would do that for everyone. It's not going to be ala carte.
Resistors are inexpensive part, so will leave those in. I could also use cheap-*** ebay LED's in mass, but I am uncertain of the quality.
Subbing MUR820's for everyone would be an extra $2.50.
Looking for some opinions.
Postive Rail -
1-IRF9610
1-IRF9530
1-BC550C
3-2SK117GR
Negative Rail
1-BC560c
1-IRF610
1-IRF530
3-2SK117GR
Positive LV
3-2SK117GR
1-IRF9610
1-MJE15029
$7.50 per rail
Negative LV Rail.
3-2SK117GR
1-IRF610
1-MJE15030
Est. Price is 7.50.
I'm interested in the mini-kits, minus the MUR's. Only because I have a stash of TO-220 hyperfast soft recovery diodes I think would work well.
I don't buy components that often, so the more complete the kit the better for me. But I'll get whatever ends up fitting most people who are interested. Thanks.
Hi Teabag,
I would also be interested in a parts kit for this board. Like Palmito, whatever suits most people 🙂
Alon
Alon
The 10uF MMK KEMET (RIFA) are the most interesting to centrally source IMHO.
I might have to buy and ship them to you, mainly to see what the cost of it is. Also some recommended Wima's from Mouser.
I am trying to keep the kit light.
I could add some more stuff, but the shipping may climb to $15 if I use the small priority mail boxes (assuming the board will fit in it, I think it does.) Those can take 4lbs of product internationally. But the box IS small. If International buyers are cool with that, that can be an option as well, and stuff it with some caps. I would assume no more than 3 rails, enough for one board) could be stuffed into such a box.
I am keenly interested in the opinions of international customers, who may have more difficulty than the US peeps. What I have above is offered at a small premium (maybe for those wages, my son might take interest in packing some) to make an easy entry point for international buyers to get product at a reasonable costs.
I don't really know how difficult or less expensive it is overseas - but I get the impression that some countries have it tough, and it gets expensive to get stuff into the country with high shipping costs and taxes.
Anyways, I can make the kit what you guys want, you just have to pay for it. But it's got to be simple for me. I am prone to shipping errors as well all know - and this could make it really bad.😀
- Group Buys
- GB Thread for Salas SSLV1.1 BiB shunt reg
