GB: Round #2; Fo-Felix EMI Filter for AC mains 120/230v; By Folsom
I will do a GB #4 once GB #3 is exhausted.
Until then just move the resistor or replace it if you are worried. There is no reason to replace GB #2-3 boards with something else when they work as intended, and can be made so the resistor wont be the secondary fuse for free or a few cents.
I would try without the DC trap. Once before on a rather different power filter it did not like a DC trap. The result was heat, however. But there is enough similarity between the two that I would give a shot without the DC trap first.
You are more than welcome to post pictures or diagrams, if we cannot quickly despatch the solution.
Finally finished my first Fo-Felix. My soldering skills could stand improvement but I think it'll work.
As long as none of them are cold soldered then it's no big deal. You should be able to see solder flow onto the pad of the via. One you have that, it should all be good even if you have a little extra solder. Obviously you shouldn't be able to wiggle anything freely.
