I believe all requests were sent. But anyone who wants in just say how many, it isn't too late, and there will be numerous extras (just how printing works).
hello,
any suggestions for a good case for this?
thanks,
drmike
I had wondered about a GB for some enclosures. They are kind of spendy if you want them machined, but price goes down rapidly as you get more. eBay is full of boxes.
I could get quotes on a GB if I knew how many sockets people wanted. I'm sure they'll be something like $100 for an extruded aluminum that's anodized, and possible min order of around 20-30.
A couple of questions for the designer and builders, sorry for the ignorance:
- What parts come with the PCBs ? Only the Weco terminals ?
The parts we need to source will be :
4x - X2 Capacitors of 0.47uF
1x - CMC of desired max AMP
2x Fuse clips +Fuse ?
1x - REsistor 110K 1W
Discharge resistor for X2 capacitors - 2x of them ? What value and watts?
How should one design the max AMP for a given 2x200W power amp ?
I have 230V, and the amplifier has 2x 300VA toroids.
Should i assume this can pull around 1A each (2A total) but with peaks of 10x this?
That would be a 20A CMC, am i thinking straight ?
Thanks!
Thanks!
Thanks!
The email was sent. But to answer the question about what is included, only the PCB and Weco connectors (big gray ones at the ends)
Info one wattage was all in email.
- Group Buys
- GB: Round #2; Fo-Felix EMI Filter for AC mains 120/230v; By Folsom
