GB For Salas SSLV1.3 Ultra-BIB
Please may you put me down for 1x board with the corresponding 2x positive and 1x negative mini kits, thanks! Target voltage is low for all three regulators: 5v to 15v - maybe upto 24v absolute max (by the way, does specifying 5v have any drawbacks? Does it affect performance or limit max voltage you can set for example?).
diyAudio Chief Moderator
Joined 2002
No true drawbacks, 5V is within spec range. Specifying 5V is about getting handpicked low IDSS J3 so its VGS(OFF) will not be high and squeezed at what VDS minimum J3 will see with 5V out (VDSJ3=VOUT-VGSM2). So its just for guaranteed 5V performance and not affecting any higher range. The Spice open loop gain analysis shows same high gain same shape and same 60 degrees phase margin at same zero gain frequency both for 5V or 15V output by the way. But a real M2 MOSFET will have lower Ciss Coss Crss parasitic capacitance curves the higher the VDS across it (i.e. Vout in this circuit). So you may say it will be performing faster beyond 10V but its no slouch at 5V.
In the sign up sheet it says DC Flexy (2 boards) $16.
Since there are 2 per board, you would get 4x DC Flexy modules for $16 if your name is down for 1x DC Flexy. Is that correct?
GoJuice, not sure if Tea has gotten back to you, but for $16 one gets a pre-scored pcb that can be separated into 2 modules. It is a simple but thoughtfully designed module.
