GB For Salas SSLV1.3 Ultra-BIB
Understanding the problem is so much better than just getting an answer. Now I have an answer and I learned something!
In this case because peak load current can't exceed the CCS limit we preset for it, prediction of AC ripple is much easier because we simply plug CCS Ampere as I_Load in the formula. Losses from theoretical DC rectification level are steady with this kind of regulator. 😉
Finally got my 24v bipolar setup complete. What a great reg - rock solid! I may have to further optimize current draw or find some better suited heat sinks, as M2 is quite hot. Is there a max temperature I can run M2 without performance degradation?
Congrats. Try not to run it with more than 60C on its sink. Not a matter of performance but of heat radiation manageability and long term reliability. M2 won't instantly break before 175C core temperature. Optimize current limit (CCS) setting VS load max mA draw spec first. Leave 100mA headroom between the two.
Gents, I need your help, I get something wrong.
I have a raw DC supply, intended to feed two pos and one neg shunts that share ground on load side.
The negative one is puzzling me. How should I attach it to the raw DC?
Thanks for helping me not shorting the PSU + and -
The Group buy for salas boards is now open and will close on October 4th 2020 at 9PM ESTI am starting to send out invoices to previous group buy purchasers.
I will be sending out private messages as well with instructions as well in the next few days.Please be sure that your spreadsheet cell meets your requirements, then read the instructions in the group buy FAQ.
Salas Group Buy Comprehensive Information - Google Docs
Once complete, reply to my private message with required information.
Private message me with any instructions. I assume you know what your ordering and have components not ordered to complete project.
