How genuine might the other 2SK369 offers on eBay be? I'm not scared of a little matching, it's just that I don't want to buy any fakes...
Hi TB,
I removed my interest on minikit because I hoped that it will contain Toshiba's 2SA970BL (I have plenty of all other parts..)
Try to find the ones that are on ammo tape.
What is a suitable replacement for 2SA970BL?
The minikit will use BC560c from Fairchild, probably on the order of 10 of them to get a good matched set.
I've never known Zhoufang (who lists them) to sell any fakes. Of course I cannot vouch for him. IDSS will typically measure from 10-16ma. So if you order from someone else, they should be in this range, and as vGeorge says, they come on ammo tape for the one's I have seen.
The ones I' ve bought in ammo tape were all genuine.
I also first, had the bad luck to buy some not on tape and they were fakes🙁
Hi Tea-Bag. I want to remove interest in the mini-kit, if it's not too late. If i am late i'll buy the mini-kit
Board and Kit Interest
Hey Teabag,
I have added myself to the list for (2) boards, (2) mini-kits, (2) sets of Caps and (2) sets of Heat Sinks.
Thanks for putting this together,
David
Hey Teabag,
David
I changed my order to 1 board 1 mini kit and 1 set of heat sinks.
providing I am correct in thinking one board does a stereo pre-amp. My friend lost interest on me 🙁
James
James
Okay, I have added a column for 2SK170 kits. They will be 3 pair.
They, as the manual states will focus on the following ranges.
Q4 8.2-8.5mA I pairs
Q5 for 7.5-8.5mA pairs
Q6 with >Q5 up to 10mA spec pairs.
The kit will be 16.00 as a line item.
You can add the column to it to express interest. I am having someone measure these up for me, so these like the 369's, may ship a bit later at no extra costs.
I will try to start getting the final GB details together today and send out the Private message details in the next day or so. If you need to be on vacation between now and the 22nd of September, let me know and I can invoice you know, assuming you don't mind a bit of variance on the parts you get 😉
- Group Buys
- GB for Salas Folded Simplistic Phono PCB
