Just like to clarify that the relay diodes (1N4001) are non critical and I can use 11DQ10s, UF4007s I have lying around right? 🙂
Got my boards and resistors yesterday.
Really well done.
Thanks a lot
Andrea
P.S.: can i ask for the post# in which to find the latest schematics and BOM?
Really well done.
Thanks a lot
Andrea
my blog blips should have all that attached.
http://www.diyaudio.com/forums/blogs/tea-bag/173-second-round-dcb1-group-buy-has-begun-1-1-2010.html
Tasso,
you show up as shipped on my list.
Last time it took up to a month (a some after) to get there boards. Hold in there.
Boards received, they look great. This is definitely going to be easier than point to point wiring! Thanks, Tea Bag, and others, for a great project.
I am currently out of PRP and Takman resistors. I might be able to order more of them, but the Tak's would have to be at at least 1/2 watt in the 220k section (read more $). If people really want these I will order maybe 5-10 sets of each. I still have about 70 boards total left. Once I get a bit lower, I will bleed the stock out slower if original buyers haven't gotten their packages, so I don't run out if theirs gets lost.
Based on last time, most had arrived at the 4 week mark.
Of course I can order more boards, I was hoping to have enough to put off ordering more until June or so, if demand is still there for it. 🙂
Hi Tea-bag, I have received the PCBs and resistors in excellent condition. Thank you, you done the great job.
Best Regards
MartinTie
Best Regards
MartinTie
Hi everybody,
time ago I bought a finished BoZ, I wondering if it is possible to transform it in a DCB1.
The 25K Alps pot seems to fits, but the trafo is 2x30 Volts! Becouse of enough room in the case I would also add an headphone amp.
Any insight?
Cheers
Peppe
Any insight?
Cheers
Peppe
certainly will need to ditch the transformer, or find some way to roll down the voltage a bit.
Ok, so maybe is better to add a trafo for the B1.
I am searching for an headphone amp pcb/kit now. I need the B1 feed my active desktop speakers and a solution fo my high impedence headphone too...
- Group Buys
- GB for DC coupled B1 buffer with shunt PSUs
