Gb: F5 Pcb
You guys are building some nice amps, I think I found my next diy project. This is a lot of information for a first time amp builder to take in, thanks for helping to simplify it (somewhat). I need to hook up with Cviller for boards first if still available. For stereo I need 2 F5 boards 1 Psu board and 2 bridge boards, is that correct? One more question, is it better to order parts kits from Tech-diy or should I order individual from the Pom for best compatability with the pcb boards? Thanks for the work you guys put ino this.
Tony
Correct, on top of speaker outs/RCA inputs switch, fuse, IEC, etc.
Ordering from Tech-diy will be the easiest solution, and 10 or so pages back mentions that jack from techdiy worked with cviller to ensure proper fit/compatibility
Scott,
Welcome to club Cviller! Purveyer of the finest boards available anywhere!
I love my F5 boards and how well it sounds with good quality components, Christian is always willing to answer any questions you may have. He's a very nice guy. I still owe you a beer next BA..........!
Scott, (again)
Someday I'll PM you with a problem I have with my Hafler DH200 and beg for assistance.
Ron
Yummy.
I just cannot resist, here is some (excuse the term) solder porn. 😀
Glad to see this thread still kicking!!
My F5 is working great but I have a slight hum in both speakers that I would like to get rid of.
The speakers are very efficient at about 95db and with no music playing I can hear a hum from about 3 ft.
I was wondering if anyone is using a "star ground" and if so how is it connected??
I would like to try this to see if it will help.
Thanks Christian, I have wired my F5 as per your picture above.
At this point I do not have anything connected to a "chassis ground"
only the safety ground is connected which I have tried both on and off.
I have been moving my gear around latley and will take some photos as soon as I can....
Rtate,
If you unplug the RCA interconnects from the F5, is there still a hum?
If not then it is caused by an upstream piece of equipment or cable.
Next try, Unplug the other end of the interconnects, CD / preamp / receiver, whatever, leave the interconnects on the F5 side, try them one at at a time, left then right. Sometimes it can be a bad cable.
Sometimes the interconnects act as antenna. But you knew that.
Try unplugging everything from the power except the F5. Hum still? Is the transformer bolted down tightly?
Keep us informed, especially if you DO find the hum source, it will help someone else.
Ron
Thanks Guys, I did some investigation when I got home from work and once again Never Assume!!!
Turns out that the F5 IS dead silent.
I have a plate amp that is driving the low frequency drivers and that is the source of the hum.
So I still have a problem, just not the F5.
Now, for some more investigating....😉
