Re: Re: Re: Re: Re: heatsinks
So you're using the Conrads or the surplus ones?
Tea-Bag said:
LabJR,
I have the Surplus heatsinks we discussed earlier running with the PD F5 board. 3-4 hours and I can still grab the heatsink for a long time. The conrads (I have four of these now) I think are overkill for F5. The surplus heatsinks I have are ~13" X 7 1/2" X 1" fins (sorry for english measurements).
This weekend should be warm, so I will crank the house heat to 75F and run normal bias and let it run all day to see if it will have some room to run in the summer.
As we calculated earlier, these are .50 c/w sinks. If it's close, I will glue a bunch of PC heatsinks on the inside, since the board itself takes so little room.
Re: Re: Re: Re: Re: Re: heatsinks
Using the Surplus ones. Saving the Conrads for future F3 build.
Check it out.
http://picasaweb.google.com/notcopperonly/SpareHeatsinks#
I am letting a few pairs go.
Shameless plug.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=138212
Check it out.
cviller:
I´m also a new member, I´ll sent you an email to order some pcb´s. I need only PS pcb´s.
Thanks.
Thanks.
Welcome!
Go to your settings to activate the email button on your profile, then people can send you private messages (emails). You can find my email address on the WIKI.
Cviller, could you please upload 1:1 pdf's of both PSU and Amp boards? Accurate holes are my freind 🙂
rhysh said:Cviller, could you please upload 1:1 pdf's of both PSU and Amp boards? Accurate holes are my freind 🙂
Sorry, I forgot that.
f5_letter.frontassembly.pdf
f5_a4.frontassembly.pdf
cviller said:
Thankyou sir.
Anychance of PSU board also?
rhysh said:
Thankyou sir.
Sure.
psu-crc_a4.frontassembly.pdf
psu-crc_letter.frontassembly.pdf
Just want to thank cviller for the GB. The board arrived in good shape. Now is time to hunt a good pair of good heatsinks for them.
I cant find any spacers with a built in bottom screw, just like a motherboard spacer. Looking for M3 size but i cant find them anywhere! I probably dont know the proper name.
R
R
Spacers
Rhys
I have some brass ones, can't remember what size they are. Two types long and very short.
The have female and male ends.
I'll have to see how many I have, not a lot. Give me an email, and I'll search them out for ya.
Brett.
Rhys
Brett.
I have some extra heatsinks
I ordered a few extra heatsinks from Conrad and put them up on ebay
search "Conrad Heatsink" or look for item 150326642235
GBF5_ORDER
I would build an f5 amp: are still available f5 pcbs and psu pcbs?
Needed a couple as main board as psu. Will buy with paypal.
Anto
Anto
Here is an example on how you could choose to wire the F5. I have intentionally left out the mains wiring part because that is very nicely described in the F5 article and I don't want to be blamed for any house fires... 😉
http://viller.eu/audio/2009jan_gbf5/P1070474_wiring1.jpg
I received my boards today. They arrived in great shape and they look really nice. Thanks for the prompt delivery.
cviller said:I have intentionally left out the mains wiring part because that is very nicely described in the F5 article
Could you point me to the F5 article?
Thank you very much.
Note that there are still two pairs of Conrad heat sinks left on ebay.
- Group Buys
- Gb: F5 Pcb
