Funniest snake oil theories
Neil DeGrasse Tyson when discussing poor human perceptions...."You know those books with those pictures of squiggly lines, optical illusions, your brain can't figure it out, they should be renamed "brain failures"".
------------------------------------------------------------------------------Rick...
The funny thing is that cryo treatment could cause wire to become brittle, much like too much heat-treating or too much time(aging) after annealling and drawing.
And Cal, when it's a warm hunting season, folks hereabouts put any of their supplies that can take it in the local meat locker.
Fourty below works pretty well in the fall.
A local dairy man(cow-boy?) took liquid nitrogen in a large thermos on a summer fishing trip, he could flash freeze the fish and recharge the cooler at the same time!
Four days, don't know if he could have made it a week.
Hi Cal,
As far as wire goes, a metallurgist friend of mine once said that any value treating might have is instantly lost once you uncoil it.
I'll believe that! Never mind the question of returning the wire to room temperatures or higher. How long would the cryo-treatment benefits last? That's assuming the object wasn't reshaped in any way.
I had someone in high school claim that if you tapped a 3 1/2" disk on your hand, the data would fall off.
His justification was if you pick up screws with a horseshoe magnet and hit it, the screws fall off...
That's an interesting one. There is a tiny grain of reality buried deep in there under the nonsense. It's actually true that severe vibration can demagnetize some types of permanent magnet!
Along those lines: if you hold a steel rod pointing north-south, and tap one end repeatedly with a hammer, the rod turns into a weak permanent magnet. (It will deflect a compass needle if you bring it close, etc.)
This happens because the hammer blows jostle loose some of the magnetic domains in the steel, allowing them to align with the weak magnetic field of the earth. Not snake oil, this actually works, though the resulting permanent magnet is so weak as to be useless for anything.
-Gnobuddy
Has anyone ever tried cryo treating their food? 😉 Take a steak on a camping trip and not only do you not need ice in the cooler with it, you can’t eat it for about 4 days. And that’s no snake oil.
Welcome back gentlemen.
Like this:
