Funniest snake oil theories
Takeaway from that article: no-one involved apparently knew how to set up an experiment..
I suspect that someone involved may know how to properly set up an experiment, but that wasn't the goal. IOW, they know better.
There's a huge problem with properly set up experiments - they tend to start acting like they are part of Science, and thus they can vastly reduce the possibility of obtaining the results that you desire.
There is an interesting book about ********, priming, and easy-to-believe fallacies.
"You Are Not So Smart", by David McRaney.
It's a very good read, and has a terrific website (including podcasts)
Try this one, to see if you agree (or do not).
YANSS 066 – How to become better at smelling and avoiding the many varieties of ******** (skip to 15:00 or so, if listening to the podcast)
******* = male bovine dung
https://www.youtube.com/watch?v=W1RO93OS0Sk
https://www.youtube.com/watch?v=hp_c8-CfZtg
http://www.amazon.com/On-********-Harry-G-Frankfurt/dp/0691122946
Several had recommended it, so I loaded it onto my Kindle last night and started reading it this morning. I'm about 15% through, and of course I totally agree with those who recommend it.
Interestingly enough the book itself explains why many on this forum won't touch the book, not even on a bet. It contains information that will not confirm their biases that they are uber menschen who are accurate and objective in all that they do.
If you apply some of the information in the book, likely you will see the phrase "trust your ears" as being the pathetic falsehood that it is. It's a great sales pitch, though.
Thanks for those links.
There was a student.....who bull dung'd his way through a Harvard test on a subject he was not familiar with, and received an A-, leading to this story.....
https://www.metabunk.org/cow-and-bull-relevancy-and-data.t6128/#post-151005
IME totally believable. There is definitely something called Testmanship. Many of the tests one takes can be gamed.
One of my engineering profs at the University made tests where if you could answer one certain question correctly, you could figure out the correct answers to the whole rest of the test from that one answer. I pointed this out to him one day, and he said it was 100% intentional. Several times he threw me out of class when the day's topic was a review of a test, even if I was quiet and just sat there. I basically aced the whole semester.
Why is it that it is always the content that 'cannot be found' and never the ads???
A correct link is more like:
You Can?t Demagnetize Vinyl But You Can Demagnetize a Record: The Furutech (alpha) and the Stein Music DE3 Record Demagnetizers | Analog Planet
(tested)
The relevant quote would appear to be:
"Yes, but where’s the scientific “proof”. I hear you. Enter audio skeptic and ABX blind testing adherent Arny Krueger (you can read and listen to here an “objectivist”/”observationalist” debate between Krueger and Stereophile editor in chief John Atkinson) and his hydrogenaudio.org minions who mocked my and Ken’s observations and basically demanded measured proof!
If one looks at the actual HA conversation, one may find a different story:
https://hydrogenaud.io/index.php/topic,71737.0.html
The actual HA discussion conclusion was:
"Bingo. I'm confident that with the right source material any two consecutive plays of an LP, if removed from the platter and then randomly replaced back down on the platter, will be audibly distinguishable in rapid fire, needle drop [digitized recordings] ABX comparisons.
Which is just a little different from the story that Fremer published, above.
Everybody who is surprized... ;-)
Makes me wonder if he actually caught something else on the measurement.
Given that the measurement was done on the surface of the earth where the residual magnetism is 0.25 to 0.65 gauss, reliable nanogauss measurements appear to tax the imagination. Nano means 10e-9, (-176 dB below ambient magnetism) which seems like hearing a whisper in a hurricane would be outlandishly easy.
