OT/: Anyone here received an offer for a free Windows 10 upgrade?? Should I worry?
Here it is, from the horse's mouth.
https://www.microsoft.com/en-us/windows/windows-10-upgrade
Yes, but even the extensive FAQ is silent about portability of hardware drivers. Will my USB scope still work, my soundcard, my dScope audio analyser?
Jan
Jan
Take an image beforehand.
If you are not happy with the upgrade, restore the image.
You might want to take an image after the upgrade as well (before restoring the original image, if you choose to do so). That way when you later verify support for your hardware, you can simply restore the image of the upgraded OS instead of attempting a 2nd upgrade (which MS may reject since you will have already done the upgrade).
Microsoft may not know the answer either. There's likely only one way to find out.
@Jan: What OS are you running currently?
Basically, anything that runs under Win 8 or 8.1 should work with Win 10 as well.
As others suggested, making a working system backup or using a different HDD for the new install is sound advise.
I've been on one of the testing teams for the past 15 years for MS and to my mind Win7 was by far the best OS they ever made. Only bettered by the server version really.
That aside, it is not Microsoft's responsibility to ensure hardware works on their OS but the people that manufacture the hardware.
Cheers, 😉
P.S I suppose there's a good reason you posted this in the "Snake Oil" thread??? 😉
Cheers, 😉
Thanks, good advice. Am running W7 currently on all machines. I DO think it is Microsoft responsibility to ensure forward driver compatibility. You can't expect manus to design for what does not exist for years to come.
Jan
Jan
Jan, if your gear required proprietary drivers running W7 it may well need proprietary drivers fro Win 10 or it could run using the old ones from W7.
Either way, Microsoft don't provide much drivers of their own bar the basic ones that every machine/device needs to run.
Cheers, 😉
Cheers, 😉
I know that - I've build device drivers in DOS times 😉
But M$ does specify the interface for 3rd party drivers, so they should make sure that drivers designed according to that interface spec should also work in W10. But I'm not optimistic.
Sorry - back to regular programming...
Jan
Jan
Currently I am holding off Windows 10 both for home use with Lightroom and at work for PCB design and 3D mechanical (Cadstar, Inventor and AutoCAD) I cannot afford any problems or down time so I am waiting till the software has been in regular use... Still on W7 for the same reason.
Though I do understand that placing 4 of these under any PC or Laptop will make your software run 25% faster with less data drop out and an overall reduction in internam EMC based noise....
Stereotimes Review Bybee Quantum Signal Enhancers - Audiocom Latest News
Think of it as turning your PC into a Cray supercomputer for a few dollars...
The review it linked to was, I thought, one of the stupidest things I ever read. Then I noticed that the "reviewer" was also in the business of selling complementary questionable items with wild and unsupported claims.
I often feel the need to take a shower after confronting the abject dishonesty of high end audio.
Found out more about him....
So do I know in bleach...I often feel the need to take a shower after confronting the abject dishonesty of high end audio.
And now you can use all that electricity without producing magnetic fields:
Steinmusic InLine Cable products cancel magnetic fields
audioCONinternational seems to sell a whole range of holistic remedies 🙄
Hi-Fi Tweak Products, Audio Tweaks for Equipment & Cables - Audiocom
OPPO BDP-105D Audiocom Signature
so let's set up a listening / viewing test to hear what a 37 or 77 Fempto-second clock can do for you 😀
Elongate yur air particles!
Steinmusic H2 Harmonizer Signature Package
Maybe the elongation inhibits the gas transfer function of the lungs alveoli; this would starve a customer's brain of oxygen, rendering the concept the appearance of fair exchange.
If only Nic Tesla had had them in 1890 .And now you can use all that electricity without producing magnetic fields:
- Member Areas
- The Lounge
- Funniest snake oil theories
