Full Range Speaker Photo Gallery
RS 1354 with planet10 treatment on the front
Eastech 5.25 midbass on the rear
Third pic is a better pic of the driver in the old cabinet.
I Have An Interesting Idea
Imagine if the drivers in these horns were mounted in 160 Azurahorns instead of that black piece of wood. Now imagine the back of the drivers in the Azurahorns were connected to the throat of these horns, so that when you looked at them from the front, it would look just like two large circles.
Now instead of having the horn's mouth exit to the side, have it exit to the bottom instead. That way when you looked at the speaker the circle on top would be the driver in the Azurahorn and the circle on the bottom would be the mouth of your horn! I bet that would be interesting speaker, no?
Thetubeguy1954 (Tom Scata)
Thanks to all,
head1962,
They sound good to me. I made the plans myself. I calculated and build the horns 7 years ago using calculator and information from James Melhuish’ site.
Drivers are stripped and modified EX3; CC~3 liters; throat 75cm^2; effective length 3.5m; mouth 0.8m^2; profile Hipex M=0.8;
doubtingthomas
I have described the build, but most of it already disappeared from cyberspace.
http://www.diyaudio.com/forums/full-range/109685-why-not-mdf-34.html
thetubeguy1954,
You just described Azura PP horn, it was a very good idea indeed.
By the way, I am 1 hour NE of Orlando. If you would like to listen to my horns, it can be arranged
Thanks to all,
thetubeguy1954,
Hello Marekst!
I would love to hear your horns, but I'm disabled and take heavy-duty, narcotic painkillers which causes the very real possibility of falling asleep behind the wheel when driving long distances. If you wouldn't mind extending your offer to one more person, I could have my best friend and fellow Central Florida Audio Society Member, Mike R. give me a ride. Mike, like myself, loves horns and uses tube equipment. I use a 40W/ch, 135lb, integrated, SET amp and Mike uses an extremely moddified McIntosh Mc275 power amp with a custom designed, tube preamp called "The Sculptor".
Mike is the person who takes me to all Space Coast, and Central Florida Audio Society meeting that are too far for me to drive to safely. We a great arrangement, I pay for the gas & Mike does the driving. It's perfect for both of us. Marekst I, in turn, would also like to extend to you the opportunity to listen to my system: My Audio System. I look forward to your response and hopefully getting the opportunity of hearing your horns. Oh yeah I forgot to mention I own a pair of 160 Azurahorns I'm not using that I obtained directly from Martin Seddon when I traded a pair of Paul Butterfield completely restored & modified TAD 2001 drivers to obtain...
