the floor is oak😀
im not really digging the moldings in the "whole picture". they must have came from somewhere else. oh wait this aint the home improvement forum? 🙄 sorry use to do hardwood floors.
It's all oak. Floors, oval baffle, and bases. Baffles are made from a 1x12x36 board from Home Depot and the base is made from 1x2's from Home Depot wrapped around a MDF center. Tried to match the baffles without much luck. Going to put some more Spar Urethane on the bases to try and darken the color a bit. The black is truck bed liner in a spray can. Urethane is Minwaw Spar Urethane in a spray can too. Thanks for the pos comments.
BTW, the hardwood floors and ugly molding are original from 1960. They could use work, but I'm renting so I don't care. 😉
looks like you did a pretty good job at matching the baffles. 😀 i would use a golden brown poly for the finish. maybe a light stain(i wouldnt) , but the only way your gonna get a color like the floors is after 40 years of life under the sun. ha ha. i know those floors are original. my favorite, solid oak 2" planks. a nice sand and finish and your good for another 10 years +.
planet10 said:
Oh yes... XOs in general are evil 🙂
Here are the plans for the 4.5L boxes
dave
can the boxes be used for Tang Band W3-871S?
thanks,
gychang
gychang said:can the boxes be used for Tang Band W3-871S?
Sure, but they are possibly too big....
dave
I didn't look back in this thread, but here's a little antiquity for you modern full-rangers.
The Goodmans Axiom 301. A nice old British driver, and one of my favorites.
Duo said:The Goodmans Axiom 301. A nice old British driver, and one of my favorites.
Is that a Leather surround?
hahaha, I suppose it's old enough.
No, it's a cloth surround with some sort of shiny coating on it.
Almost like it's rubberised and then plasticized haha.
It's a phenomenal driver.
Duo said:No, it's a cloth surround with some sort of shiny coating on it.
Hmm.. it doesn't look like the usual coated cloth surround - the accordion type.
I don't doubt it. I'm listening to a pair of Goodmans Twinaxiom 220c (with accordion surrounds) sans baffles, as I type. Superb.
It's a rolled cloth surround.
Actually quite a normal surround with just an unnormal coating.
It's very strong and allows great compliance.
The VAS for this driver is 320 litres or so.
Yes, sure is a nice old driver. Probably go for another 40 years.
I was offered a pair of old cabs today. A label on the back said Toshiba SSW120 8" 2-way. I need them like a hole in the head. However thought another pair of 8 inchers to try on an OB. Cutting the cotton type grill cloth revealed a 10" plus a Motorola horn. Forget about the plastic horn.
Mounted in about 25L cabs, they're a bit bass shy, also the suspension is very stiff.
These may end up on OBs. They go quite high. The horns aren't needed. That's a silk dust-cap.
Not the biggest alnico magnet in the stable, but a reasonable slug.
No date stamp. Any clues?
Geoff H said:The working side. Looks a bit like an old CTS.
Heh, other than the seamless cone, it sure does!
A driver like that should have excellent low-end if driven in a critically damped or even slightly under-damped situation.
My experience with transconductance (current output) amplifiers shows this.
Westwell. I've had a few smaller with that name pass thru. In this case, i'm going to guess a Pioneer OEM.
Looks like a nice driver. Can you run an impedance curve -- that will tell us a lot.
dave
Yeah, I'll get round to a z curve. Still re-breaking in. They have been idle for a number of years. The previous owner painted the gaskets matt black along with the baffles, and included the outer roll of the surround!!. I have treated that with mineral turps, which is helping. I'll do the entire surround with bitumen once broken in.
8 hours ago, need full bass boost, now bass control at 2 o'clock. Very promising though. Nice accurate mids, fast transients, sweet top end if directional, a bit peaky on female vocal up high, and a bit sibalent. guessing about 93 - 94 db/w compared to the modded Wharfedales.
I don't know why the unfiltered Motorola's were there, maybe he was deaf.
Geoff.
Geoff.
I just picked up these on ebay:
http://cgi.ebay.com.au/ws/eBayISAPI...MEWA:IT&viewitem=&item=110092026002&rd=1&rd=1
Seas 8.5" fullrange drivers.
Anyone know anything about them? I couldn't find any info on the net.
- Full Range
- Full Range Speaker Photo Gallery
