i am thinking about buiding a boombox for my iPod. I am not sure which speaker I should get. It will be a box similar to this on iPhone Speaker Dock Makassar Ebony | techaffine (approximatly 20 liters and BR design).
The Fostex FE166En and the Tangband W5-1611SA are in my close-pitch selection.
Which driver would you pick?
regards
eladmihttp://dict.leo.org/ende?lp=ende&p=Ci4HO3kMAA&search=between&trestr=0x8002
regards
Maybe... a driver !!
I didn't like the phisycal condivision of the baffle ,giving a narrow stereo separation . But two boxes of that size ,for the drivers you mentioned ,would be ok
A 3 sections sculptured/flared baffle, or 3 units(1 for the electronics ) than can be detachable ,better ,no ??
The Fostex FE166En and the Tangband W5-1611SA are in my close-pitch selection. Which driver would you pick?
Given it would be an ipod boom box and that the amplifier would probably be a chip amp (3875 is what I would recommend) the Jordan JX92 makes most sense. Another option is the Fountek FR135 (available from Madisound). If you are looking for a larger driver why not a Mark Audio 10 or 12?
I picked the Tangband W5-1611 for my small sealed speakers due to its flat response. I plan to add a little EQ to it to bring the bass up, but will measure its response before I do anything. If I recall correctly, my math shows an f3 of 98 Hz with a 6 liter sealed box without EQ.
~Tom
This is a simple drawing of the box
1 = TK2050 Amp
2 = SMPS
3 = iPod power supply
What do you think?
1 = TK2050 Amp
2 = SMPS
What do you think?
I still would like to emphasize on correct channel separation ,as the result of good mechanical damping of the enclosures . One would object that the greatest energy in motion is that coming from the bass ,which is in phase . So we should separate the basket of the driver from the rest of the box ; this can be done with cork ,or with special bits that have around neoprene/gumlike .
Edit: for a driver in the middle I intended a real woofer servicing for bass ,making it into a 2.1 . Then ,button-size drivers could be placed at 45° and tilted .
I was also thinking of making each speaker detachable and having a folding stand (like pic-nic tables) . Or making the box 'movable'..like the center part allows four wings to exit ,making it an H frame for the subwoofer (like early photographic machines ).
Meanwhile ,now when writing ...(nuclear station working alot !!!! )I invented a system that supplies the stands and is the fulcrum in separating the 3 elements : each speaker is held to the center body by a long barrel that catches the two rings above and the two in the bottom . These two sticks when removed , can be inserted in the bottom of an enclosure (assuming a wooden basis with two holes is put below !!! )
I finished my project a couple days ago. I used the Tangband W5-1611, Hifimediy T2 and the Meanwell SP 320.
Pics:
Videos:
Box playing
Seal works good
I hope you guys like it.
Cheers
Pics:
Videos:
Box playing
Seal works good
Cheers
Very sad, no comments at all!
I added a clip in HD:
YouTube - [diy] Wodden iPod/iPhone Boombox TK2050 + W5-1611
Cheers
Cheers
I like 'em !
They are very 'professionally' done indeed . can you tell me if you feel the need to enlarge the stereo image as I suggested ? Two boomboxes are better than one !
may be not ... By the way ,in one-cabinet-two speakers , each speaker 'sees' the asymmetric baffle ,but when they are stand-alone in one cabinet ,obviously they should not be positioned in the center .
Awsome!
not to late to use a grain filler, high gloss lacquer and polish. would really make the unit pop. nice work....
Grain filler is good idea. I will give it a try this weekend. I am not good in lacquering and i don't have the equipment. I have used wax instead.
- Full Range
- Full Range Speaker for iPod boombox
